Komatsu D20A track tension
   / Komatsu D20A track tension #1
bwj123
Williamsport
komatsu d20a
I am trying to get my track adjusters to work with no luck. I have books, manuals (none worth a sh..) and someone in the business, but we are stumped as to how to proceed. Anyone out there with a background in Komatsu "recoil spring" track adjusters for this small dozer? Thanks, Brad
   / Komatsu D20A track tension #2
I'm assuming these are standard hydra-justers, as we called them. There should be what appears to be an inspection cover approx. 6" X 6", or so near the front of the cover, over the adjuster assy. Possibly a section of the cover over the barrel of the adjuster, that is removable. Under there, you will find a grease zerk. Give it a few shots at a time, then pull up, and back up a couple times, letting it take the slack out of the track. Then check the sag in the track, with a straight edge. Usually a good inch was pretty decent.
If you pump them up too tight. Under the zerk on what we had, looked to be a nut about 3/4" or 1" depending on the size of the tractor. Back this out slowly, and it will release grease, and tension off the track. Just go a bit a a time, until you see grease coming out.
Not really familiar with a Komatsu, but the Case, John Deere, and Fiat-Allis we had were pretty much the same in principle.
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
CRAFTSMAN ZERO TURN MOWER (A53843)
CRAFTSMAN ZERO...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
DOOSAN G25KW...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
