Kohler V twin engine Life
   / Kohler V twin engine Life #1
GTSRider
Cub Cadet 3000
I have a 3000 series with the Kohler 20hp V-twin engine.
How long can these engines last with good maintenance ?
Engine had 400 hrs. when I got it, and I put 55 on it in 3 months.
It uses about 3 oz. every 3-4 hr's .... is this about normal ?
Pete
   / Kohler V twin engine Life #2
I've seen them with over 2000hrs on them and still running strong. Mine don't use 3-4oz in a year/~30hrs, but oil consumption can depend on how it's used and how hot the ambient temps.
Joel
   / Kohler V twin engine Life #3
It depends if it's a Kohler command or courage model. I understand the Command lasts about twice as long as the command.
   / Kohler V twin engine Life #4
Hey, you're not making any sense.
Hey....now I'm more confused as ever.
I have the Command 20 hp ....she runs strong.... but I do run it ALWAYS
at full throttle, up hills for 3 hrs straight.....and in the summer hood gets
so hot I can not touch it.
Pete
   / Kohler V twin engine Life #6
Pete, does it get super hot where you live? Regardless of Kohler's 10w30 spec, I always run 15w40 heavy-duty engine oil in my small air cooled stuff. It will take the heat much better than a regular passenger car 10w30 will and will burn-off less, if not stop the consumption all together. If your scared about extreme cold winter time starting, synthetic 5w40 heavy-duty oil flows better cold than a regular 5w30 does.
In regards to the above statement, the Command series engine is Kohler's "premium / commercial" line, where the Courage is typically "residential grade". I've got a Courage Pro series V-twin on my Z-Force. The only major hardware difference between it and a Command twin is my Courage requires manual valve lash adjustments as opposed to the Command's maint free hydraulic valve lash adjusters. The Courage single cyl are a different bird all together.
Joel
Hi Joel ...yes it does get hot here.... plus I mow 3 acres of hilly terrain,
and the oil suggestion is a good one.
I have been thinking of using Shell Rotella 15 /40.
The 10/30 oil is a Tractor Supply oil sold by the gallon.... but I feel the Rotella
will be far superior.
Thanks for your input.
Pete
   / Kohler V twin engine Life #8
Go to just plain 30 weight,thats what I use in all of mine,,bet you won't use as much or any oil.
   / Kohler V twin engine Life #9
using straight 30w below 50 degrees can cause the lifters to over pump and hold the valves open causing engine to die and not restart for a few hours while the lifters collapse. Seen mainly on the single cylinder command engines but can occur on the twins also.
   / Kohler V twin engine Life #10
Well,I only mow grass in warmer temps:D,50 plus,,,,,but,don't think any thing will happen to your motor if you use 30 weight at 45 degrees.
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
Sellick 560 Forklift (A57148)
Sellick 560...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
JOHNSON JW12 OUTBOARD MOTOR (A58374)
JOHNSON JW12...
