Mowing Kohler K301
   / Kohler K301 #1
carryonkaty
Wexford, PA
Allis Chalmers 12hp
I have an Allis Chalmer lawn tractor with a Kohler K301 engine. It's run great for years but now runs on kangaroo juice.....the plug is very black. Cleaned the carb and set the points to 20thou and fitted a new plug. It sounds like fuel problems but any body any ideas.
Thanks John
   / Kohler K301 #2
I recommend doing a static points adjustment (using the timing mark on the flywheel) and adjusting the valves while you're there. The .020 gap rarely puts it in just the right spot. If none of that makes a difference, then your coil is probably on the way out.
2020 Toro 6000 Series 60in Zero Turn Commercial Mower (A50322)
2020 Toro 6000...
City of Lakeland (A51691)
City of Lakeland...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
Chevrolet C8500 Flat Bed with a Moffet Kit (A52748)
Chevrolet C8500...
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
2018 JLG 1932R 19FT Electric Scissor Lift (A50322)
2018 JLG 1932R...
