kohler engine acts like its starving for gas intermittantly
   / kohler engine acts like its starving for gas intermittantly
i'm curious if someone can explain to me how the new "electronic" needle and seat works. i have taken the bowl off when cleaning the carb. it appears the flow of gas is controlled by an electrically actuated plunger instead of the old style needle/seat/float that i am familiar with. these seemed to show up about the time CARB compliance started and the EPA was mandating cleaner engines.
i'm wondering what actuates this device and what the failure mode is.
i'm wondering if it could spontaneously shut off the flow of gas into the carb for a few seconds of if a spring internally might be broken or loose.
i think it is only sold as part of the carb so that might mean a new carb anyway, but i would still like to try to understand how these new fangled things work ;-)
amp
   / kohler engine acts like its starving for gas intermittantly #12
amp
Amp,
I am 99% sure these are the "Safety" shut off valves on the carbs and do not do any metering. Yes it is possible you are loosing the signal to it. Would require a test light or meter to check voltage. I have never heard of one of these failing but... being man made it sure is possible. I would think that a Kohler dealer would sell them as a seperate item. JD may not.
JD MAY have requested a special engine model number from Kohler so that it makes buying parts from any one but JD difficult. I know JD had Kawasaki do this to their motors used on JD equipment.
good luck
Roy
   / kohler engine acts like its starving for gas intermittantly #13
"i'm curious if someone can explain to me how the new "electronic" needle and seat works."
That gadget (electric solenoid)at the base of the carb bowl isn't a needle and seat. It's purpose is to reduce the risk of backfires when the engine is shut off. When the key is turned off the solenoid blocks the flow of fuel to the main jet. You should hear the solenoid "click" as the ignition is cycled on and off.
These solenoids do fail, or, more likely, the wiring or connections to the solenoid. I worked on a riding mower today that had a faulty connector on the wire between the solenoid and the switch that caused the engine to intermittenty starve for fuel. When you wiggled the connector you could hear the solenoid clicking.
Some folks fix this problem by removing the solenoid and replacing it with a simple bowl bolt. That also fixes the problem of a dead battery if you leave the key on. The solenoid draws enough juice to kill a battery in 2-3 days.
   / kohler engine acts like its starving for gas intermittantly #14
I have a 16hp version of your tractor. I added a fuel filter to the line a few years ago (it did not have one) and it started having very similar symptoms to what you are describing. I ended up cutting a few inches out of my fuel line to compensate for the length of the filter. The problem went away. Some how the added length/change in elevation was affecting fuel flow under certain conditions.
Matt.
thanks for the all ideas and information! next time i mow, i'll try out these new ideas and post back.
if i don't post for a few days it's because the wife is due to have our second baby within the week, so there will be higher priorities than mowing!
amp
   / kohler engine acts like its starving for gas intermittantly #16
You'd be amazed at how many problems like this have been created by adding/swapping the original inline fuel filter for one that "fits" or "looks the same". I'm all for saving some $$ by using aftermarket stuff, but only if it's truly equivalent to the OEM part.
The biggest caveat with using aftermarket inline fuel filters on small engines like this, is that many of them simply are not designed to work with the fuel pumps that many small engines have. If your engine has one of the OEM pumps that operates off of the pulses from the crankcase, it's best to spend a few extra dollars and buy the original recommended filter instead of installing a generic inline filter from the parts store.
We have three Toro Dingo walk-behind skidsteers in the rental fleet with 20-25 hp Kohlers. They have all acted similar to the issue the OP is describing after someone replaced the original inline filter with a generic one from Napa or Carquest. Those small fuel pumps simply do not produce as much "oomph" as a larger mechanical or electric pump like a car or light truck has. You think you're doing the engine a favor by staying on top of the maintenance stuff, (and even more so by adding a larger filter that looks better), but you often wind up causing problems when the fuel pump can't suck the gas through the element
Probably the most common Kohler fuel filter number in use on these engines is a part # 24-050-02. My garden tractor with a 20 hp Kohler takes that one, and the Dingos do as well. The parts manuals for the machines even list that number.....the machine manufacturers don't even try to sell their *own* part.
I wouldn't bypass or eliminate the carburetor solenoid. They're easy to diagnose, and inexpensive to replace if, (unlikely), they go bad.
   / kohler engine acts like its starving for gas intermittantly #17
Hi,
I am trying to diagnose a very similar problem. My Kohler is 4 years old and is acting like its starving for gas after about 40 minutes. If I disengage the blades and wait a bit it seems to recover for a short time again. The fuel filter is clear and only has a little gas on the bottom, barely any.
This spring I changed the fuel filter and plug. Thinking it may be a bad plug I just changed that again and it was not the issue. I am getting ready to find another fuel filter but I used the recommended Kohler part so it most likely is not the issue.
I would gladly pay to have it repaired but I do not have a way to transport it and there are no in home repair availible to my area. Are there any other "dummy proof" things I can try?
ok, check this out.
i had occassion to use the mower heavily this week. before starting, i decided to unhook the solenoid wire just to see what would happen. if working correctly, my understanding is this action of powering down the solenoid magnet should allow the spring to push the needle into the carb orifice stopping gas flow and the engine should not start at all. if this is incorrect, someone please advise....
well, imagine my surprise as the engine ran flawlessly for about 5 hours of mowing!
i know.... that is bizarre, right?
i guess that points to a defective solenoid but failing in an odd way intermittantly. i imagine the needle just kind of floating around in the end of the assembly periodically plugging the orifice when the governor demanded more fuel. as for why it doesn't do this when the wire is unplugged beats the heck out of me.
well, whatever works. it doesn't leak and the engine runs great so i'm leaving it unplugged and mowing like a fiend....
hope that helps somebody.... ;-)
i will also add that i am running an aftermarket fuel filter (hastings i believe?) and that doesn't seem to have an effect on the engine performance in any way.
   / kohler engine acts like its starving for gas intermittantly #20
Good to know I'm not alone, apparently this is a common symptom with Kohlers.. aside from those caused by bad fuel & filters. I have a 6 month old Kohler Pro CV492S 18hp and it starts and runs fine for 30-45 minutes then begins to stall like it's has fuel starvation or out of gas. Wait a while and it will run again which makes it sound like a temperature related electrical problem. The carb fuel bowl solenoid shuts off fuel flow to the carb when the key is off and prevents dieseling too.. might also be tripped by a safety tip over sensor to kill the engine. I read on other forums that the solenoid can become corroded by water in the bowl and cause trouble but I found a repair tech had already disabled the solenoid by cutting off center pin on mine.. For another shot to find a cure I used a can of dust off to chill the ignition module on the chance it was hot (even though it was cool to touch, apparently some designs get warm enough to require a heatsink). One forum suggested the fuel line was getting hot and causing the fuel to vaporize but I don't think it's the problem here. I have good fuel flow from the tank to the bowl with a new 60 micron filter & new gas. Guess I'll keep reading.. the thing farts when I shut it off too.
2014 MGB BLENDER (A45333)
2014 MGB BLENDER...
2023 New Holland Workmaster 70 (A44391)
2023 New Holland...
Fleco 48" 26.5T Long Reach Excavator Smooth Bucket (A42203)
Fleco 48" 26.5T...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
2012 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4CFB55706 (A44391)
2012 Ford F-150...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A44572)
2018 Toro...
