Kohler CV 12, no spark when warm
   / Kohler CV 12, no spark when warm #1
lobsta1
I have a CC 1315 with the Kohler 12.5 spec 1211. For the last year I have been fighting an intermittent starting problem. Headlights not turning on all the time led me to a flakey ignition switch. No cranking at times & stomping down on clutch/brake pedal led to replacing the deck switch. Still having problems starting at times had me bypassing reverse switch. Still starting problems that I finally realized usually only happened when warm. Cranks fine, but no spark at a grounded spark plug. There is no separate coil on this model. This leads me to think that the ignition module/magneto is failing when warm. Before I spend $50 on a new module, does this sound like I am on the right track.
Thanks
Al
   / Kohler CV 12, no spark when warm #2
i would say that u might be onto something, cause if it dont start when warm, it would usually be a coil. I would see what some of the other guys say too.....good luck and keep us posted
   / Kohler CV 12, no spark when warm #3
while I would ditto the failing coil, might want to pull the cooling shroud sheet metal off that engine first - clean it good and inspect all exposed wiring (particularly the coil ground ing wire) for any damage. Wont cost anything but the time and may save you some money - if you find plugged up fins or a ground wire capable of shorting out... Just don't run the engine with shroud off.
Tried all this on Sunday. No change, so I ordered the coil today.
Thanks
Al
UPDATE
Thought I would post an update. When I got the new module, before I installed it I decided to check the existing air gap. I'm a dummy. Should have done that first. Supposed to be 10 > 12 thou. Had virtually none. Must be why I could not ohm it out. Put the new mod in & all is fine. Checked the resistance on the old mod with it out & I had 14 thous. So it looks like I have a good spare.
Al
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
UNUSED FUTURE FT380R STAND ON SKID STEER (A57192)
UNUSED FUTURE...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
