Kohler Carburetor Problem
/ Kohler Carburetor Problem #1
ly134
Gas vapor and gas liquid coming out from throat of carb. Have installed NEW Kohler carb and still have the same problem. Pulled head and decarboned head and cleaned around valves. Engine is a Kohler Magnum 8 hp installed in a Model 122 Cub Cadet. Thanks for the help.
/ Kohler Carburetor Problem #2
Sounds like blowback thru the intake valve. Perhaps timing is off. or intake valve is burned. Did you examine the mating surfaces on the valve and valve seat for good seal ? Is the valve clearance adjustment ok ?
Not real familiar with the magnum but maybe also compression release mechanism malfunction.
Ben
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
Michelin Mach X BIB 710/70R42 Tires (A65640)
Michelin Mach X...
(16) Kinze 3000 Seed Boxes (A65640)
(16) Kinze 3000...
2022 EZ-GO ELITE...
