Kohler Carburetor Problem
   / Kohler Carburetor Problem #1
ly134
Gas vapor and gas liquid coming out from throat of carb. Have installed NEW Kohler carb and still have the same problem. Pulled head and decarboned head and cleaned around valves. Engine is a Kohler Magnum 8 hp installed in a Model 122 Cub Cadet. Thanks for the help.
   / Kohler Carburetor Problem #2
Sounds like blowback thru the intake valve. Perhaps timing is off. or intake valve is burned. Did you examine the mating surfaces on the valve and valve seat for good seal ? Is the valve clearance adjustment ok ?
Not real familiar with the magnum but maybe also compression release mechanism malfunction.
Ben
2015 Hooper T/A Trailer w/Mounted Foaming System (A53117)
2015 Hooper T/A...
2006 Hummer H3 4x4 SUV (A51694)
2006 Hummer H3 4x4...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
Concrete Mixer Mini Skid Steer Attachment (A51691)
Concrete Mixer...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
2018 Freightliner M2 106 Lay Flat Roll Back Truck (A51692)
2018 Freightliner...
