Kohler 8 HP rebuild - ?
   / Kohler 8 HP rebuild - ? #1
Mattc8832
West Virginia
John Deere 3032e,Snapper Pro SW20 and s200, Stihl Handhelds, BCS 830, Yamaha Rhino 700, 2 - Gravely 5260, New Holland LS 45 , 6,10 by 14 Trailer , Woods BH 6000 Towable Backhoe, Honda 21 Self Propelled, Exmark Commercial 21and shop full of tools
We tore down the 8hp kohler last night. I seen that it is .020 over piston so it had been bored. It is low on compression. I noticed a a lot of carbon build up on the piston could that be a sign of a lot of oil burning due to needing rings. Question can the rings that came with the OEM rebuild kit work on a .020 piston? I'm going to reuse the piston just clean it off - I'm putting a new rist pin and rod on the oil piston. The piston looks to be in good shape.
thanks
   / Kohler 8 HP rebuild - ? #2
What did the spark plug look like? It should tell you if you are burning oil.
   / Kohler 8 HP rebuild - ? #3
As I recall, the rings are larger on the .020 over piston. You can also be getting oil through the valve guides. Is this a cast iron engine? It's been too many years since I rebuilt one to be sure, but I think that if you put a bare ring down into the cylinder (with the piston removed) the gap between the ends of the ring should be about .100" If much more, you need new rings.
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2021 FREIGHTLINER...
7'x20' Homemade Trailer (A50123)
7'x20' Homemade...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A51692)
2004 Pierce Tilt...
2025 K731G UNUSED Flower Bed (A53117)
2025 K731G UNUSED...
