Kohler 8 HP rebuild - ?
   / Kohler 8 HP rebuild - ? #1
Mattc8832
West Virginia
John Deere 3032e,Snapper Pro SW20 and s200, Stihl Handhelds, BCS 830, Yamaha Rhino 700, 2 - Gravely 5260, New Holland LS 45 , 6,10 by 14 Trailer , Woods BH 6000 Towable Backhoe, Honda 21 Self Propelled, Exmark Commercial 21and shop full of tools
We tore down the 8hp kohler last night. I seen that it is .020 over piston so it had been bored. It is low on compression. I noticed a a lot of carbon build up on the piston could that be a sign of a lot of oil burning due to needing rings. Question can the rings that came with the OEM rebuild kit work on a .020 piston? I'm going to reuse the piston just clean it off - I'm putting a new rist pin and rod on the oil piston. The piston looks to be in good shape.
thanks
   / Kohler 8 HP rebuild - ? #2
What did the spark plug look like? It should tell you if you are burning oil.
   / Kohler 8 HP rebuild - ? #3
As I recall, the rings are larger on the .020 over piston. You can also be getting oil through the valve guides. Is this a cast iron engine? It's been too many years since I rebuilt one to be sure, but I think that if you put a bare ring down into the cylinder (with the piston removed) the gap between the ends of the ring should be about .100" If much more, you need new rings.
TAKEUCHI TS80R2 SKID STEER (A51246)
TAKEUCHI TS80R2...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53473)
2017 KINZE...
2021 JOHN DEERE 1725 CCS LOT IDENTIFIER 178 (A53084)
2021 JOHN DEERE...
2004 CATERPILLAR 262B SKID STEER (A51246)
2004 CATERPILLAR...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
40' CONTAINER (A51248)
