Kodiak Rotary cutter and Pats easy hitch - don't fit!
   / Kodiak Rotary cutter and Pats easy hitch - don't fit! #1
TmbrWlkr
Kubota l3400
I was excited to play with my new class 2 rotary cutter built by Palidan/Kodiak. Low and behold my Pats system is just a bit too wide ( bent the attachment pin, the one with the hole in it that receives the the positioning bar).
The machine is all I could have hoped for as far as performance. The Pats system is on my Kubota L3400 - which I am selling. I am hoping my new Kioti DK5010 with extendable lower link arms, telescoping sway bars, and hydraulic positioning lever (for the 3pt), will negate or minimize the need for the Pats system; as I included them "in the deal" for the L3400. We shall see. I have a couple of other "captured pin" implements, but they have not seemed to be a problem. Just a heads up to anyone with a Pats system considering this cutter.
   / Kodiak Rotary cutter and Pats easy hitch - don't fit! #2
I could be wrong but it looks like the a frame should be bolted in the rear hole and the pin should go in the front hole . all of my implements are set up that way
I will check that out (doh!) - see, that’s why I am here - good info.
I will report back if it possible (or not) to move it.
   / Kodiak Rotary cutter and Pats easy hitch - don't fit! #4
maybe it's a photo illusion, but that pin "looks" really small for cat 2
   / Kodiak Rotary cutter and Pats easy hitch - don't fit! #5
Whole assembly looks odd.... Seems to be designed for only ball end of lift arms...
It’s a class 2” - but Cat 1 - but; pin is small in the hole.
PROBLEM SOLVED - I switched the location of the pins and bolts - good advice here. Pins ARE a little small, and linkage still seems the be flexible.
thanks all!!
2013 JCB 3CX Extendahoe Loader Backhoe (A55973)
2013 JCB 3CX...
2013 RAM 3500 FLATBED (A58214)
2013 RAM 3500...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
