Kobota L235 lift arms won't raise
   / Kobota L235 lift arms won't raise #1
joemjones
finger,tn.
farmall C
been working great it set though most of winter every thing on it works great but the arms won't raise
so I changed the fluid still not working
it sounds like air pocket and has a gurgling sound when you try to raise the arms
dose any one know what it mite be and how to fix it
   / Kobota L235 lift arms won't raise #2
You have a screen filter on the transmission that becomes full of crud overtime. Mine is a 245 and it is located on the left side of the trans. As you sit in the seat drop your left hand straight down. It will be under a little oval steel plate held in place by two bolts. Mine is about the size of a big cigar. Look on the internet and see if you can find a good diagram. Used to be less than 20.00, for the filter.
   / Kobota L235 lift arms won't raise #3
Maybe you should learn how to spell the name of your tractor and internet searches would work better.
   / Kobota L235 lift arms won't raise #4
Nasty.
I think that's how I got my B7610 so inexpensively, the guy couldn't spell Kubota and it didn't turn up in the search engines. Plus he thought it was a La352.
OP - Also check to see if the valve that controls the 3 pt lowering speed adjustment hasn't been cranked closed.
   / Kobota L235 lift arms won't raise #5
Welcome to TractorByNet!
We moved your thread to the Kubota Owning & Operating forum. :)
MURRAY 22" 2N1 SELF PROPELLED PUSH LAWN MOWER (A51248)
MURRAY 22" 2N1...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
DEWALT 4400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 4400 PSI...
(APPROX 72) UNUSED LANDHERO WHEEL STOPPER (A51248)
(APPROX 72) UNUSED...
2017 Kia Cadenza Premium Sedan (A51694)
2017 Kia Cadenza...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
