Front-End Loader KMW ML260 quick attach system - needing info
/ KMW ML260 quick attach system - needing info #1
SETXShooter
Bridge City, Tx
2005 Mahindra 6000DI
1st post - here goes...
I've bounced around this site for a few years and now that I am 2 tractors rich, I figure its time to dive in.
I recently bought a 2005 Mahindra 6000DI 2WD. It has a KMW ML260 FEL and I would love to add a QD/QA system to it. I searched some through posts here and googled a bit but the only thing I have seen so far is a Titan Universal system that I would have to weld the mount brackets to it.
Does anyone make a QD/QA system for this loader?
/ KMW ML260 quick attach system - needing info #2
Are you referring to a "universal" skid steer quick attach (SSQA)?
Two other QA systems (that I know of) are the "global" / "European" QA and the "John Deere" QA.
Yes, welding the system onto the FEL will be a requirement due to the forces (and abuse) that the attachments & loads will inflict. And all of the attachments (bucket, pallet forks, bale spikes, etc...) will need to be compatible with the QA system that you choose. That compatibility may, or most likely will, add weight to the implement employed which, in turn, will decease your lifting capacity.
Yes, SSQA. Is there a brand that sell as a direct fit for the KMW ML260?
By weld on, I meant the brackets that allow a "universal" bracket to fit my loader by welding brackets to the SSQA device. Titan sells a slick back SSQA device that you weld FEL specific brackets on to. Hoping for a ready to pin on system that does not require welding.
/ KMW ML260 quick attach system - needing info #4
Have you seen this company? Skid Steer Quick Hitch Adapters
Call them, this one might work:
No, Have not seen that company. Looks like the ticket for bolt on vs weld on. I will have to call tomorrow to get a weight estimate as I can't find it on their site. Would like to compare it to the Titan weight wise.
But $115 for shipping seems a bit steep.
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
Zero Turn Mower (A59231)
Zero Turn Mower...
Johnson 3pt 12' High Speed Disc Harrow (A64119)
Johnson 3pt 12'...
