KL120 Quick Attach?
/ KL120 Quick Attach? #1
mathey
Platinum Member
MD
NH TC33D
Is a Quick attach available for the CK20's KL120 loaders? The Kioti website doesn't show one as being available...
The wife was quite impressed when she used her Dad's NH TC24 with the QA over the weekend... "then I could switch from the bucket to the forks when you weren't around" /forums/images/graemlins/smile.gif
Mark
/ KL120 Quick Attach? #2
Yes it is , but not thru Kioti. It is a aftermarket peice.
We do have them instock.
/ KL120 Quick Attach? #3
Wallace. I sure wish you had mentioned this before as several people had asked me about it and I told them I didn´tknow of one. Guess I should have asked the forum myself! Thanks, John from WARM Mexico!
/ KL120 Quick Attach? #4
------ Great how much are they and lets see what they look like, I have been looking found a couple others but not impressed with them at all...............
/ KL120 Quick Attach? #5
I am in the same boat as this is the only thing holding me back from pulling the trigger on a CK20 with the KL120 loader. Not taking anything away from Wallace, Michigan Iron also has an adapter for the KL120. Unfortunately, that still would leave you with the standard pin-on bucket that would also need to be modified to cut the ears off and weld on an adapter plate. This seemed like a lot of work when the Bobcat version of the CK20 (CT122) has the quick attach as an option.
I guess it's sort of the like Chevy and Cadillac are both GM but different trim levels.
/ KL120 Quick Attach? #6
We have converted a few with no problem. In every case the owner has mentioned that the loader lifting capacity has been noticeably reduced due to the bucket sitting out further.
Just a word of caution.
/ KL120 Quick Attach? #7
You will lose a small bit of lift capacity with the QA as mentioned. The factory setup will do the same thing. There is no way to fit a QA between the bucket and arms and not gain a few inches. I switched mine on a KL130 and haven't seen that much of a loss to the point where I wouldn't want the QA.
/ KL120 Quick Attach? #8
The KL130 is fine with the QA setup. It all depends what you are lifting with the CK20. If you need to lift a heaping buckets of gravel it won't quite do it any more. But if you are not using the loader to full capacity than the versatility of the QA is great.
