grapevine said:I have never had a loader, so maybe I won't notice the issue with the type of work I have for it.
fiddleback said:just paroozin' but you do now that increasing the bore of your cylinders DOES NOT give them more power, but it will make them slower. Increased pressure gives more power and likewise, increased flow makes them quicker! Right? Tom
HODAK said:Increasing the cylinder size will increase the power. It gives more surface area for the pressure to work on.
You are correct.............surface area(pi x radius squared) x pressure. Increase either one and you will get more power.
No I haven't.rback33 said:Vince, have you seen the new linkages for the 1590/1595 roll back kits?
Thanks Jeremy..It's amazing how similar the new linkages we designed are to the ones you fabbed for your 1450. Well done my friend.
DK35vince said:I checked my KL 1450 pressure relief valve setting a while back.
My tractor was delivered with the loaders relief valve set at 2250 PSI.
The loader owners manual calls for a maximum relief setting of 2300 PSI.
So I set my pressure at 2400 PSI.
