KK Disc Report
/ KK Disc Report
You probably would be better not using as much weight or no weight and just making more passes,disking down to where you want,takes many passes,its a disk,not a plow or rototiller.
Plus you got to maybe adjust it so's its not as agressive,gotta work with the tools you have,or buy new tools.
I wasnt complaining about the disc....just trying to report on my experience with a new piece. It just takes a while to figure out how to operate a new piece of equipment....as I havnt operated anything in the way of plows or discs for many, many years....and things have changed quite a bit....like 4WD. :D
This disc is a pretty good piece and I dont know how I could have bought anything better for my situation. Seems it operates a little better with more use....or maybe its my imagination. Also....my diff-lock sure comes in handy...lol. Anyway I am quite satified with this disc. It does take a few passes....but I am getting very good penetration and soil mixing. On some of my food plots...this is the only way to "turn the soil"...you are not going to run a plow through some of the stuff I am discing (over tree stumps and rocks) ....at least not without a whole lot of other work first. For a small disc...this one is well built and has good adjustability.
/ KK Disc Report #22
Wasn't meaning you was, was just saying that sometimes it takes a while to figure out the best way for you to use a tool for your application,sometimes it don't work out exactly like we figured in our head,so we gotta make adjustments.:)
/ KK Disc Report #23
I pull that same disc with a JD 4720. Bought it when I had a 3320. I wish I had a floaring disc rather than a 3PH. Do you have the front and rear set at the same angles? (I.E. bolt holes #'s) I have issues leaving a furrow at the outside of the rear gangs. Any answers for this?
/ KK Disc Report
Suncoast.....so far I have set the front and rear at the same angles and I am one hole back from the most aggressive setting....both front and rear. I have noticed a furrow at times....but I think it's more of my operating in some irregular plots (???...not sure about this) rather than the disc performance. We have followed the disc with a flexible tooth harrow (pulled by a four-wheeler)....which smooths any furrows remaining.
I think your right about the performance of a pull type disc vs a 3 point mounted disc. I believe you would get better performance from the pull type. For me, the 3 point is mandatory as I could not turn around with a pull disc in many areas due to the trees.
/ KK Disc Report #25
As with most "rules" there's a bit of flex as to what works and what doesn't, but as a general rule of thumb, I usually set the rear gangs to one position less aggressive than the front. And I always put a worn disc blade on the outside of the rear gangs....one that is a few inches smaller diameter than the rest. That reduces the dead furrow left behind by a bit.
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
2014 Ford F-250 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-250...
Hydraulic Tilt Bucket Mini Skid Steer Attachment (A59228)
Hydraulic Tilt...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
