Price Check Kioti's
/ Kioti's #1
enterprisebbc
Ct
2008 CK35 Kioti
How much [ballpark] # is a new 35hp loader/BH Kioti? Are the motors now all computerized? thanks
/ Kioti's #2
I didn't price a 35hp model, but a DK40SE (hydro tranny) was a bit over $22k with FEL, dual remotes, rear work light, and 7-pin connector. The matching hoe was in the $7k range. I'd take a little off both for the CK 35hp model. They are running a special now that advertises the CK30 HST for $16,999....so maybe split the difference, and figure $19k, or thereabouts for the tractor with FEL.
/ Kioti's #4
As far as the second half of your question, that's a good question. On Kioti I don't know. I did look at an LS R4041 the other day and I asked this specific question and was told no computers. The automatic water drain on the fuel system I was told is actuated by a timer/relay system. I have been poking around on Mah and MF as well in the same 30-40hp class and they don't appear to have computer controls at this point. But I think as the Tier 4 mandate gets fully implemented in this HP range of tractor I think some manufacturers will be using computers as part of their emissions management systems. B
/ Kioti's #5
I cant answer on the first part of your post as far as the 2nd part .....Computers on the tier 4 will show up on most all of them eventually... the DPF is the worst thing we have run into on the newer emission engines... Lower emissions usually mean better fuel consumption which is good for us end users which I have no problem with... The DPF though is a item you have to maintain which adds cost to usage.
I went ahead and bit the bullet and bought a new kubota last month. I would have liked to have waited a couple more years before getting a new one but decided to go ahead and do it before they all have a DPF on them. If you can get one with no DPF Id get it.. a computer will not cost you anything over the tractors lifetime unless it goes out.... a DPF needs cleaned,clogs up, or either will need the fuel treatment/oil added.
/ Kioti's
THANKS everyone
/ Kioti's #7
I have a BOBCAT CT 230 and with BOBCAT phasing out of the compact tractor lines I am still suffering sticker shock re adding a FEL even with their "phase out" pricing. So has any one else switched manufacturers and added a KIOTI FEL to a BOBCAT base compact tractor. The obvious situation is that the two lines appear similar in other respects. I have not yet checked with the KIOTI folks before I go any further.
Thanks, Ed
/ Kioti's #8
That Bobcat base is in fact a Kioti so I would not worry about it. Oh yea, Welcome to TBN
/ Kioti's #9
You will need a rattle can of white paint. Otherwise you should be good to go.
/ Kioti's #10
Was surfing the Branson site today and seems the EPA emission standards are increasingly stringent. On the Tier 4 is said to add about $3k to the price of the tractor.
Mark
2002 John Deere 737 Zero Turn (A63116)
2002 John Deere...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63118)
2019 Cadillac XTS...
2019 Bobcat E85 Excavator (A63109)
2019 Bobcat E85...
SECTION OF PALLET RACKING (A63745)
SECTION OF PALLET...
2014 HYUNDAI 53X102 T/A DRY VAN TRAILER (A59910)
2014 HYUNDAI...
