Kioti1914 no hyd. power
   / Kioti1914 no hyd. power #1
stinkypete
In a bind here. I've got my father- in -laws tractor. Sudden loss of hydraulics. What are the possible probs. Is there a shear pin in the pump or a relief valve that could be causing the problem? Is this a dealer only repair? Is there something I could check first? Any help is appreciated. Thanks ,Pete
   / Kioti1914 no hyd. power #2
How old of a tractor is this and how many hours? Have you checked your hyd fitler and how is your fluid level? Does everything loose hyd power or just one thing?
   / Kioti1914 no hyd. power #3
There is a relief valve down by the differential lock pedal. Could someone have turned it the wrong way? There is a pin in the knob to keep you from going to far (high) but you can lower it enough for you to have almost no hyd power. There is a hyd filter. When was it cleaned or changed last? Check these things and let us know. The user manual shows both the hyd relief valve and the hyd filter location.
2011 JACK 130BBL (A53843)
2011 JACK 130BBL...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2008 CHEVROLET C7500 SERVICE TRUCK (A51406)
2008 CHEVROLET...
