Kioti1914 no hyd. power
   / Kioti1914 no hyd. power #1
stinkypete
In a bind here. I've got my father- in -laws tractor. Sudden loss of hydraulics. What are the possible probs. Is there a shear pin in the pump or a relief valve that could be causing the problem? Is this a dealer only repair? Is there something I could check first? Any help is appreciated. Thanks ,Pete
   / Kioti1914 no hyd. power #2
How old of a tractor is this and how many hours? Have you checked your hyd fitler and how is your fluid level? Does everything loose hyd power or just one thing?
   / Kioti1914 no hyd. power #3
There is a relief valve down by the differential lock pedal. Could someone have turned it the wrong way? There is a pin in the knob to keep you from going to far (high) but you can lower it enough for you to have almost no hyd power. There is a hyd filter. When was it cleaned or changed last? Check these things and let us know. The user manual shows both the hyd relief valve and the hyd filter location.
Chevrolet Tahoe SUV (A52377)
Chevrolet Tahoe...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A53843)
2013 KENWORTH T800...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
DOOSAN G25 GENERATOR (A53843)
DOOSAN G25...
SAND BLASTING CABINET (A53843)
SAND BLASTING...
