Kioti won't start when wet or cold(snow)
   / Kioti won't start when wet or cold(snow) #11
I've looked over the battery connections and they are nice and clean.
This is the mistake we made with mine. The connections look fine, it's not until you pull back some of the insulation that you know there's an issue. I'm not saying this is it for you, I'm still betting on the switch, this is just info for the group. I've also taken part in other discussion here on TBN where this turned out to be the problem, it's a strange one that is very hard to figure out.
   / Kioti won't start when wet or cold(snow) #12
This is from somebody who never saw Kioti closer than from 100 yards. Most newer tractors have a shutdown solenoid on the injection pump. Check if there is voltage on the solenoid when the key is on. Also check that the glow plugs have voltage on them when turned on.
Ops. I didn't read the original post completely. Since it doesn't turn the engine I would also think that you need to check
1.) the ground connection.
2.) Is there voltage on starter solenoid or do you hear it at least clicking.
3.) If it is clicking then it might be faulty.
4.) If it is not clicking the key switch is most likely bad.
   / Kioti won't start when wet or cold(snow) #13
If you are having problems when it is damp and cold or evenreally dusty outside you may want to check a number of things.
1. I'd check all of my electrical connections for good connection, and make sure there is no water or corrosion in the connectors.
2. I would try spraying the ignitionswitch with a water dryer solvent first and then come back with the electrical wash and a good electrica spray lubricant.
3. KIOTI ha also been known that in tractors built prior to mid 2009 had relays that weren't water or dust tight and could get moisture and dust in the relays and cause the same issues that you are running into, dealers in Texas and Oklahoma and the Grat white North will remeber this.
4. We all like to keep a clean tractor but when you wash it no power washer or spray nozzle near any electrical connection or relay cause they aren't water tight and designed to have that kind of exposure to the elements. I know it sounds crazy it's a tractor should be able to be around these conditions bu the Koreans aren't known for always using the best products for the applicaton.
5. I would recommend that you unplug all of your connectors clean and place dielectric grease in the connections and put back togther and spray with a water displacement spray or gel. I would do every connection on the machine, I have dealt with this issue for years and have seen it on thousands of machinea.
Hope I hav been able to be some help and good luck
   / Kioti won't start when wet or cold(snow) #15
I just replace my ignition switch on my DK50 HST. Had same identical problem as yours. If i would turn key off whole way and then to start position fast it usually started but never from the cycling threw the glow plugs. Mine was under warranty so i just stop by dealer and they gave me a knew switch to try. Fixed the problem and took 10 minutes tops to replace. Pulled 3 screws out, unsnapped wire harness, plugged new in and put threw switch hole on panel and screwed panel right back on. Im not mechanically inclined but i'm gonna bet it's ur Switch.
   / Kioti won't start when wet or cold(snow) #16
If it were just not cranking when cold or extremely hot then I'd look at the battery. Since it seems more of a moisture or cold, but not sub-zero conditions I'd look at the switch and you could also take the ground cable at the battery and grab it and move it around then try cranking to see if that changes anything. If it does then the cable or connection to the battery may be suspect. Whatever it is I suggest cleaning the battery terminals after removing them from the battery posts and then spraying the posts and terminals with a battery terminal spray to keep them sealed and devoid of moisture/oxidation. Get the plastic cap from Kioti that protects the ig switch from water/ moisture and install it regardless of what the problem turns out to be.
   / Kioti won't start when wet or cold(snow) #17
Is it just not cranking? If so check the clutch switch also. If they get moisture in them and freeze they won't complete the crank circuit.
Hello,
Thank you all for the help. My tractor is now starting fine. As there is no dealer around here, I bought this used, I wanted to see if I could get it going without having to buy a switch, the most likely culprit given all the posts here. If I couldn't replace it quickly, I wanted to try cleaning it. One poster suggested contact cleaner, and liquid film when clean. I bought the can of cleaner and ordered the liquid film from Grainger.
When I started spraying the cleaner in the key slot and wiggling the key in it, black residue came out the bottom and remained on the key. I cleaned the key off and re-applied the cleaner until the liquid was clear.
Next, the acid test, try the tractor. Now at this point the temperature as about 8 degrees with little sun on a high humidity day. I hear a click, and it turns over! It took a little longer to start in the cold, but start it did. Since then it has started every time I have gone out to clear snow. I consider this problem well and truly solved for now - maybe the switch will go bad in the future. When my liquid film comes in, I will be spraying that in the switch t try to protect it from the elements.
Thanks for all the help.
   / Kioti won't start when wet or cold(snow) #19
If you have a Bobcat dealer around, you probably could get some parts from them if it's a hurry. Tell them it's a CT225 Bobcat. Otherwise you could contact a Kioti dealer, some post here, and they will be happy to send you the part. Another member here recently picked up a Bobcat glow plug and it had the same part number as a Kioti. The tractors are the same except for the fel, bh, and a few odd parts.
Those ignition switches are the culprit for many electrical problems when they get dirty.
   / Kioti won't start when wet or cold(snow) #20
MTUser said:
Hello,
Some ignition switches have a cover to keep the grit and grime out. I am guessing your's doesn't. What about a marine ignition switch cover? Here's one where you remove/reinstall the ignition switch and put a threaded piece in there to hold a rubber boot that seals the dirt and moisture out. What about something like this?
http://www.jamestowndistributors.com/userportal/show_product.do?pid=11378
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2019 TerraGator 7300 Spinner truck (A56438)
2019 TerraGator...
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
2021 BOBCAT S66R SERIES SKID STEER (A60429)
2021 BOBCAT S66R...
Case skid steer wheels and tires (A56438)
Case skid steer...
