Kioti vs Bobcat loaders
   / Kioti vs Bobcat loaders
Sure. But the limiting factor is how much less curl can you live with? Increasing the
moment arm (distance betw the force and the pivot) multiplies your force, but the
range of motion is less.
Also note that increasing your breakout force this way will also put a greater induced load
on your loader boom and its hyd cylinders.
I understand what you're saying on range of motion, but I would think the opposite would be true in regard to stress on the machine. It would seem like the loader cylinder, arms, and hydraulics would actually be working easier with a higher pivot point... Less resistance during the curl motion, compared with having it low on the quick attach plate.
   / Kioti vs Bobcat loaders #12
If you can increase any force by increasing the leverage, that higher force has to be resisted by
the loader boom.
By increasing the breakout force with my homemade bkt forks, I can now lift over 2000# near the
ground, using the curl function. That weight is certainly a higher load on my loader boom and
boom cylinders.
the loader boom.
boom cylinders.
With all things equal, considering one would be curling the same amount of weight, wouldn't it be easier and less stressful for all mechanical components involved, if the curl cylinder was pinned higher (for leverage) ?
   / Kioti vs Bobcat loaders #14
If you lifted the same weight and only changed the bucket pin spacing for the curl cylinders, then
the only elements that would endure less stress would be the bkt cyls and where they attach at
both ends. The ends of the forks or bkt that lifts the weight would endure the same stresses
either way.
But of course, everything will not be equal in the real world: the loader gets operated to relief
quite often when digging dirt or lifting with forks. The additional leverage allowed by increasing
bkt pin spacing increases the force limits where the FEL acts on the load.
Hilti TE 2000-AVR Electric Jack Hammer (A55973)
Hilti TE 2000-AVR...
2018 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2018 ALLMAND BROS...
Hose Reel (A55787)
Hose Reel (A55787)
2012 Ford Expedition 4x4 SUV (A56859)
2012 Ford...
2018 Ford F-550 Altec AT48S 47ft. Bucket Truck (A55973)
2018 Ford F-550...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
