Kioti UTV MEC2200 wont start
   / Kioti UTV MEC2200 wont start #1
Mike No one
Kioti Mechron UTV
I turn the key, nothing. Dashboard lights on, no blown fuses, 12 volts at starter and in battery. Any ideas?
   / Kioti UTV MEC2200 wont start #2
Welcome. Clean the key switch, check relays and do you hear the regular solenoid clicking sounds or not? How many hours, how old is the battery? BTW, Battery needs to read above 12.5 volts to be any good …
   / Kioti UTV MEC2200 wont start #3
Try and jump start it, probably the battery, enough juice for dash lights etc. Probably wont do the starter clicking like on a car with a dead battery. My RTV had the same problem
   / Kioti UTV MEC2200 wont start #4
Check your neutral lockout switch - if it thinks it is in gear it will not let the starter engage. Should be a relay in that circuit too that could cause the same problem.
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
2016 Freightliner M2 106 Altec AM50 50ft. Insulated Material Handling Bucket Truck (A55852)
2016 Freightliner...
SHOP CAGE WITH CONTENTS (A55745)
SHOP CAGE WITH...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
