kioti starting problems
/ kioti starting problems #21
Thanks for the update - glad you got it running. :thumbsup:
I'm sorry for not being clearer, I guess in times like this it would be far easier and faster to include a picture or two!
We do have places that will test batteries. The stupid thing is, every time battery load testers come on sale at our local hardware stores, I think about buying one and never do which is silly because they come on for $30. Well, I can guarantee I'll be buying one next time I see one in the flyer!
Thanks again for everyone's help and input.
/ kioti starting problems #23
I read this whole thread in hopes I could find a possible hint of what my CK30HST is doing. No Luck.
My tractor seems to work 100% but then randomly I will turn the key and get "the click". This is after the glow plug finishes, I wait a few seconds and turn the key. Sometimes it starts immediately, and (like I said) randomly just clicks. When the "click" happens I turn the key off, wait a about 15 seconds and turn it again. Sometimes it starts PERFECTLY and then again randomly it will click again. If the tractor "clicks" it will usually start on the next key turn. I always wait for the glow plug light comes on (if it does) until it goes off. Never jump the gun. My CK30 is about 13 years old and has a new battery (exactly what it came with) installed about 9 months ago. When it does start after the initial "click" I don't think it turns over one complete revolution before it is running. Acts as it did brand new.
All maintenance has been kept up. Tractor looks Brand New. Now all of that was a mouth full. Not sure if it's a failing key switch, starter or solenoid. I read somewhere on this form that there was a lot of talk about key switches and Kioti tractors.
So... does anyone have any thoughts or experience with this kind of issue?
Thanks to all...
/ kioti starting problems #24
I've heard so many Key Switch stories that is where I would look first ! Spray some WD-40 in the key hole ?
/ kioti starting problems #26
Try Highgear's advice before doing anything invasive.
Give several shots of WD-40 in the keyhole (through the little straw with key out) and then stick in the key and cycle it through the positions several times. I fact, I recommend folks do this annually as preventative maintenance.
The switch is not that hard to replace or disassemble-and-clean but WD works just as well. Plus it's cheap, fast, and easy. If you want to know what's inside the switch go here: https://kioti.ddns.net/ignition_switch.html
2011 CARGO CRAFT ENCLOSED GOOSENECK (A67714)
2011 CARGO CRAFT...
2005 Peterbilt 357 Tri-Axle Dump Truck (A66736)
2005 Peterbilt 357...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2018 FREIGHTLINER CASCADIA 125 6X4 T/S SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
2008 Generac SD100 T3 125kVA Standby Diesel Generator (A66734)
2008 Generac SD100...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
