Oil & Fuel Kioti service intervals
/ Kioti service intervals #1
Kioti Dave
Leduc Alberta Canada
2016 Kioti NX4510 HSTC
kioti manuals have many omissions and discrepancies. On my NX owners manual, on inside cover, it says to replace engine oil and filter every 100 hrs. In part 7 under maintenance, it states tier 3 engine oil every 200 hrs or every year. Tier 4 every 200 hours. No mention of annual for tier 4. I have always changed every 100 and use Rotella T6 0W40. Probably go to 200 without issues with oil. What are you all doing?
/ Kioti service intervals #2
I change mine once per year (Rotella T-6, 5w-40)
The year we built our house I ran around 200 hours, all other years I probably average 100-115 hours per year.
Regardless I still changed the oil once per year.
/ Kioti service intervals #3
My Kioti CK4010 operators manual also requires engine oil change every 100 hrs. So for the most part, I adhere to that schedule depending on weather. In fact I am overdue now by 15hrs. Most other tractor brands, Kubota, JD and many others also follow that 100hrs oil change.
/ Kioti service intervals #4
I have a CK30HST that I bought new in 2006. I use Rotella T6 5w30 synthetic from the start. I change it in the spring and again in the fall before it gets cold. I only put around a hundred hundred hours a year on it but this is what I have been doing from the beginning. I also change oil filters and fuel filters at the same time. Transmission oil/hydraulic oil and filters every 400 hours. Again this is what I do others might think it is a little to much!
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
2019 John Deere R-4038 (A61306)
2019 John Deere...
2023 Bobcat Mini Grapple (A64126)
2023 Bobcat Mini...
1901 T/A CAR HAULER TRAILER (A59914)
1901 T/A CAR...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
HYUNDAI HL770-9A WHEEL LOADER (A65053)
HYUNDAI HL770-9A...
