Kioti RX7320
   / Kioti RX7320 #1
ironman1952
2023 Kioti RX7320pccb
My loader has a lifting weight of about 3300 lbs. Does anyone know what the tilt weight spec is? also I am going to get a teleboom, Jenkins, WIth the weight of about 800lbs and a truss weight of 300 will my tractor tip at that weight fully extended and raised?
I have my tires ballasted.
Also when in loading dirt/digging, should i be in low range 1st or 2nd gear???
Kind Regards, Joe
   / Kioti RX7320 #2
I would definitely get some 3 point ballast if you're going to have your loader all the way up and extended boom. Breakout force is listed as 5369 lbs.
   / Kioti RX7320 #3
I'm not a qualified engineer but some napkin calcs would put you over the limit before starting. You'll probably fold up the loader arms. You don't specify the extended length, but a general number is about 22 feet. That would put a load at the arms of over 24,000 lbs. 😲 Forget about break-out capacity.
I would rent a crane or a crew to do it.
2014 Peterbilt 320 Altec AH150 Boom Truck (A49461)
2014 Peterbilt 320...
New/Unused 12ftx20ft Steel Carport (A48837)
New/Unused...
5ft 8in Tarter Gate (A48837)
5ft 8in Tarter...
JACTO 105 GALLON 3PT HERBICIDE SPRAYER (A50459)
JACTO 105 GALLON...
Set of 4 Mitas 20.5R25 Tractor Tires (A49346)
Set of 4 Mitas...
Ford Super Duty 8ft. Truck Bed (A48081)
Ford Super Duty...
