Kioti PTO help needed please
   / Kioti PTO help needed please #1
osobuco
Indy, IN
Kioti LB1914
Hi all. I am new here and I have a problem with the pto on my LB1914. it kept disengaging when under a load and now the lever is flopping around and it will not engage at all. there is not any end play in the pto shaft and no leaks. I am thinking it is a broken or bent shifter fork. to repair this will I have to split the tractor or can I access it through the back?
thank you for any and all help
mike
   / Kioti PTO help needed please #2
Check what the lever operates. Is there linkage involved or does it connect directly to a shaft protruding from the transmission case?
There very well could be a problem externally.
378813 (A51573)
378813 (A51573)
2020 BOBCAT T770 SKID STEER (A51246)
2020 BOBCAT T770...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
UNUSED GOLD MOUNTAIN M202010 20'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
(INOP) FORD 8N / 9N TRACTOR (A51247)
(INOP) FORD 8N /...
