Kioti Problems
   / Kioti Problems #1
ninja
I need to know all the problems that the Tractor "Kioti LK3054" has had/having.
My main interest is "WHY" would a clutch keep going bad when the tractor is not being abused.
Ninja
   / Kioti Problems #2
I gave you some things to check or have checked;you're problem is certainly unique. I have an '05 3054 and while it's not trouble free, has no where near the bugs your's apparently has.:(
   / Kioti Problems #3
mine is an 02 or 03 cant remember order of the serial number to be sure. i bought it new has 348 mostly hard hrs on it now from loader work to plowing,disking,pushing snow,blowing snow. i do a ton of clutching and have not even adjusted the clutch since new. the only problem is cold starting. i put a tank circulator on it when i bought the tractor, 40 bucks from napa plug it in for half an hour befor use. i hardly ever use the glow plugs.
   / Kioti Problems #4
I had one in my shop a couple years ago and the power steering motor (which is located in the steering colum) had a seal go bad and leaked fluid into the clutch housing and that tares up a clutch real fast.
   / Kioti Problems #5
Ninja, did you see smoke or smell the clutch burning up each time?
   / Kioti Problems #6
What is the condition of the clutch when it goes out?
Is it burnt? Or shredded? Is the flywheel blue?
Need more information.
BTI
   / Kioti Problems
Yes, all of that Burnt, some sherding and flywheel is blue. From my heart I AM NOT ridding the clutch. Only use the clutch to change gears. I use the speed gear to slow me down if needed. Thanks for the reply.
2018 Ford F-250 Extended Cab Reading Service Truck (A50323)
2018 Ford F-250...
2018 Ford Ecosport S SUV (A50324)
2018 Ford Ecosport...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51243)
FAE UML/SSL 150 VT...
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
2002 Chevy 3500 Dump (A47384)
2002 Chevy 3500...
