Buying Advice Kioti NX or RX and horsepower needed
   / Kioti NX or RX and horsepower needed #51
Yes, it would be much cheaper to hire it done, But if he is the same as me, I have a fairly high stress job and my days off spent in the tractor are better then sitting on the beach to me.
It seems as money isn't the object, he want's to do it himself, I was just giving him some info to do that.
   / Kioti NX or RX and horsepower needed #52
Many of us feel the same way. However that type of tractor recreation is not compatible with mowing ten acres in ninety minutes and for most of us doesn't start off with a big landscaping project that needs to be done quickly even though we'd never operated any tractor before. The OP seems a bit impulsive and would benefit by sitting on his wallet for a while and take time to contemplate the issues. In the meantime he could get a few estimates for getting the work done professionally.
   / Kioti NX or RX and horsepower needed #53
I have been keeping up with most of this thread, here's my :2cents:
CM and IT have given great advice, I understand Thorholt's opinion also. If the OP would have extended use for the equipment then I would say go for it and get the RX series tractor. So far I haven't read that future needs are a must. Buying new and doing the work with the intent of selling is just giving away a boatload of money. Based on what I've read, I agree that the OP should just hire the work out unless he has future long term use of the equipment.
Coyote & IT, thank you very much for all the advice you’ve given. I knew you’d veto thorholt’s idea, but I truly appreciate everything I learned from you just on this thread alone.
And thank you Lynn.
IT: you said outsourcing would cost me 10-20% of 40,000…that is 4,000 - 8,000.
There are 3 immediate projects: drainage 1,000 feet, grading 3 level acres, and fencing 1,600 feet.
Frankly, and based on some estimates I got and outsourcing I did for this property, it is impossible for the 8,000 to cover any one of those three projects…and I am not counting material, just labor and their equipment.
Do you want to make a guess how much I spent to cut 120 trees, haul them away, and grind stumps…all in 10 days?
I also have to admit, I am not trying to save money doing it myself because it will probably take me longer time to finish the tasks (given that my whole lifetime yard experience is the 85 hours mowing grass).
   / Kioti NX or RX and horsepower needed #56
No problem, youze welcome....
<snip>
Not really, but I'll bite....
Not knowing size of the trees or any other details of the site work, I'll throw out $50K neighborhood...
   / Kioti NX or RX and horsepower needed #57
And thank you Lynn.
OK, it's a bigger project than I though. I was focused on the 150 yards of trench mentioned in the original post. Is it 450 feet or 1000 feet of trench?
Cost estimates for removing trees depends on whether the trees were of commercial value and how carefully the land was restored. Could have been anything from a profit for sale of the lumber to $40-50K or higher if stumps were removed and soil restored. A big excavator could take out that many trees in a couple of days if they were just medium size trash trees. Still, expensive if there was no value to the lumber.
What still doesn't make sense to me is your focus on getting it all done as quickly as possible but you are a novice and limited to weekend work. If you want to do it yourself then you need to be realistic about time. A CUT based TLB will have at most a 9ft BH with an 18" bucket. That is adequate to dig 450 or 1000 feet of trench and 200 feet a day would not be hard to do once you became familiar with the equipment and task. Probably half the time if you rented a mini excavator though.
Spreading and leveling 200 yards of "subsoil" (what about topsoil?) would take multiple days with a CUT. Longer if you are going for accurate leveling and grading. Most landscapers wouldn't use a CUT as a skidsteer is much faster for that type of work.
Digging 200 fence posts would also be most efficient with a hydraulic phd mounted to a skidsteer. Probably five or more times as efficient as using a 3PT post hole digger. Of course digging the holes is the easy part, a rented skidsteer with phd could dig all the holes in a day or two. Using a 3PT phd on a CUT would probably take 10 minutes per hole with a single operator. Maybe five minutes if someone helped by driving or lining up the phd. Actually installing the fence would be the expensive part.
Where I live you can get an independent skidsteer or TLB and operator for about $70-100/hr on a daily basis. YMMV. Probably about the same for miniexcavator. Of course a professional landscaping company will charge multiples.
So, a "do it yourself" full time project for just the earth moving (trench, post holes, 200 yards of dirt moving) might well be accomplished in 7-10 days of actual work. Nobody digs quite as efficiently as on paper so maybe add a 3-4 day additional buffer. That's at least seven or eight full weekends with no consideration for time moving equipment, weather, etc etc. Might more realistically take twice that long for someone commuting to the work site and starting as a novice. And none of this includes time to install the fence posts or fencing or setting drainage pipe or returning spoils to the trench once the pipe has been set.
I still think that the dirt moving part of the project could be hired out or done with rented equipment and done more efficiently and cheaply than buying all new equipment and doing it yourself though. The real expenses in this project are the drainage pipe, fence and trucking.
You need to think about post project uses for the equipment to really judge what size and type of CUT would make sense in the long term. Your decision on mowing strategy is critical here. If you can accept something other than a manicured lawn look by mowing just 2-3 acres per weekend in 90 minutes then any CUT that runs a six foot mower and 8-9 ft BH would make sense so something in the 35-45 hp range. I'd be very confident doing it over time with my DK40 and Woods BH90x and Caroni TM1900 flail mower plus a phd.
Coyote & IT, great guess for the tree removal...I paid 48,000 for it. About 100 (out of 120) trees were healthy and good lumber.
IT, those are great additional details you're providing...I really appreciate that.
I can rent skid steer with hydraulic PHD for around 400 but then add 250 for delivery and pickup. But I also want to plant small trees along the fence, so I will need to add the convenience factor of having a PHD at home. Also, you're right, it may be better to rent backhoe instead of buying it.
You guys convinced me not to go over 45 hp.
I think it may be good to get the finish mower 72 inch...Kioti offers standard duty and medium duty, is it better to get the heavier (medium) over the lighter (standard) one?
Thank you
   / Kioti NX or RX and horsepower needed #59
I have to admit full disclosure - I worked as ground crew, then tree climber back in the day, when I was around 14-16. Some of the hardest work I've ever done. I'm 65 this past April, and I don't climb trees anymore, unless being chased by my resident black bear who's moved into my neighborhood. 1st time in nearly 35 years at this property I've even seen a bear within 5 feet of my house, when it flipped open the commercial recycle bin to search for ~recyclables?:confused2:
And if you're going to plant trees/shrubs and buy them from a commercial nursery they will plant them for you and guarantee the stock to survive, usually a year. It's worth it depending on what size and quantity to consider them doing it...
Some nurseries will do fencing too, so again you could bundle labor and machines to dig holes, install fence, and plant trees. Depending on size of 'small trees' you want, I don't think a PHD would be needed or used by a pro landscape crew, but I could be mistaken on that one. I'm not a landscaper; more of a cut/prune, drag or burn trees guy....
If I were you I'd investigate some of the nearby landscape companies and research, ask neighbors too, what nurseries in your area are full service. Have their head guy give you a plan, on paper, of finished project, drainage installed, land graded and sub and topsoil installed, and whatever else you need done, fencing, lights, carousel, gazebo, etc.
Sounds like you have plenty of $$, (not a slam, just an armchair assessment of your possible situation), and like a lot who do, too little time to spend it fooling around cutting your however many acres. They can give you a mow all your stuff rate too.
I say work smart, not hard! Use your resources most effectively; and for you, buying a tractor and screaming fast ZT are not best use of them, IMHO.
When you get the estimates, pick one, save on buying the tractor, hoe, hog, PHD, etc. and go out and buy a nice BMW or whatever, and show your wife, girlfriend,;) mistress :shocked:, whomever, a good time, and relax, knowing you've done a good job by letting your fingers do the walking through your local phone book. :thumbsup:
Smart money spent, better overall satisfaction, and a guarantee on the trees/shrubs and fence pieces, and the install of same for a certain period of time. What more could one ask for? :thumbsup::)
   / Kioti NX or RX and horsepower needed #60
Thank you
Regarding mowers, I know Kioti doesn't manufacture mowers so assume they are rebadged. Never heard anything bad about them so they are likely a good brand. I generally buy medium duty. Major quality brands for finish mowers are Woods, Landpride, Rhino. Other good brands too that I cannot remember. I would personally get another Caroni flail (or other good medium duty brand flail from Italy or USA). If you have nothing to do for the next week, read the big flail thread which is titled something like "let's discuss flail mowers".
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
2014 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2014 Dodge Ram...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
STORAGE FEES (A59575)
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
