Kioti NX HST can not shifting
   / Kioti NX HST can not shifting
Hopefully if it happens to someone else they can read this and learn. A lot easier to actually see what’s going on during the daylight lol and really helps to have a good friend who owns big tractors and was willing to come out and take a look at it for me. Within 2 minutes he diagnosed it. Grateful to have those kind of friends.
   / Kioti NX HST can not shifting #12
Glad it was not something bigger. I have the pin part numbers but do you have the pin sizes to get a generic one? Can't get to dealer for a while.
Thanks,
J
I have a entire set from harbor freight of various sizes Just matched it up and put a new one in I don't know the size but have plenty of backups now for the future Shifts great again
   / Kioti NX HST can not shifting #14
Hey Tiger. I think I just ran into the same issue. I am newer to tractors and am trying to figure two things…
1. Where in your photo is the roller pin? (I am trying to look at diagrams as well)
2. When you got it out did you just use a punch and hammer it out from the back or what?
Thanks for any info. I need to plow my driveway and the road to the barn and I can’t feel my fingers right now lol.
I believe it was in the first pic I posted. I sold the tractor so I can't taken any more pics but with the hydro it was up under shifter in front of the back left tire. It was not fun to punch out because it was tight and mine was broken. Once it came out it was easy to put the new one in. I did add a little epoxy to keep it from happening again
   / Kioti NX HST can not shifting #16
Just an update ended up being a broken roller pin Got it punched out and replaced and everything works well Thanks for the help
I have the same issue and like you said took 2 minutes to diagnose. My question before I start is 1. Did you have to remove the rear wheel? 2. Can you drive the pin through to remove it or did you have to remove the part to do it..trying to keep it simple(ish). Thanks.
It was tight but I did not have to remove the tire. I used a punch and a short hammer to drive the roll pin out Took a few minutes but was an easy fix when I put the new one in I put some epoxy on the outside to make sure it wouldn't happen again
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
2019 KUBOTA SVL95-2S SKID STEER (A52707)
2019 KUBOTA...
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
2005 Bomag BW266 Double Drum Roller (A54865)
2005 Bomag BW266...
