Kioti NX Backhoe/ HST Question
/ Kioti NX Backhoe/ HST Question #1
Tigershark
Shelby, KY
KIOTI NX5510 Cab HST with Backhoe
Just bought a used NX with a backhoe, its a beast. Didn't get a chance to try out all the gears before hauling it home. This evening had a few minutes and tried low, medium and high on the HST with the backhoe attached, low and Medium were fine but high didn't have any power even when I had the RPMs up. It would get going and drop down to 1000 RPMs. I am hoping it has to do with the backhoe being attached can anyone confirm that high gear won't function properly with the backhoe attached? I didn't see anything in the manuals I have.
thanks for any help or input
/ Kioti NX Backhoe/ HST Question #2
Mine runs fine on high with the backhoe attached. Only goes 15 mph and slow to get moving but is certainly intended to carry an implement in high range.
thanks for your response
That's what I was thinking, is there anything that needs to be done I have the rear hydraulics off, any other suggestions it has lots of buttons but none appear to do anything. Tried linked pedal that didn't work well, set RPms high and gave it throttle and it dropped to low and died a couple of times, I was testing on flat ground
/ Kioti NX Backhoe/ HST Question #4
No special actions are required. If it goes in low and medium it should go in high. May check your fluid level.
/ Kioti NX Backhoe/ HST Question #5
How goes the power seem when not in high range? Is the parking brake off?
Low and medium were fine, yes parking brake was off. I disconnected the backhoe last night but haven't had a chance to test drive it again.
/ Kioti NX Backhoe/ HST Question #7
I’m pretty sure you’re barking up the wrong tree.
/ Kioti NX Backhoe/ HST Question #8
Are you gradually applying HST pedal or just ramming it to the stop all at once. The higher the gear, the more you need to finesse the HST pedal to get the machine to moving. Stomping the HST pedal is the equivalent of popping the clutch in high gear on an automobile, it is just going to stall the engine if doing that.
I don't have any experience with Kioti but my B26 Kubota moves well in high range, even going up a hill, BUT, I have to back off the HST pedal as it starts to stall the engine, just keep enough pedal pressure to keep max torque on the engine without stalling it and it continues to go.
You said "set the RPM high and gave it throttle", I assume that what you meant by giving it throttle, was to press the HST pedal. Throttle controls the engine RPM only, HST controls the transmission.
TRY THIS: Advance the throttle to the full speed, then slowly press the HST foot pedal. You have to slowly engage the HST pedal, similar to what you would do with a manual clutch on a car or tractor (what some folks call slipping the clutch) to allow the engine to slowly engage the transmission when in a higher gear ratio.
Gary,
Yes I have had one for a couple of years so I have tried many things. Going to test drive it and see if it is all good without the back hoe then if it is hook up the back hoe and test again, the dealer said there shouldn't be any issues so just have to identify step by step how to recreate it. Still hoping it will be normal when driving without backhoe then work backwards until I pinpoint where I start loosing power, this all assuming that it drives normal with no backhoe
/ Kioti NX Backhoe/ HST Question #10
No BH, but if I start from a dead stop in high, I have to "let it shift gears" is best way to explain it. Linked pedal or not, low HST pedal input, let it gain some speed and build RPM, a little more pedal, a little more, then up to speed. This doesn't take a mile or anything, but just "flooring" the HST pedal in H doesn't get me anywhere. Think of your HST pedal as a powershift lever - if you've ever driven one of those it makes sense.
/ Kioti NX Backhoe/ HST Question #11
If it goes the way its been described, slow and easy on the HST to build up momentum, without the hoe, you should be good to go. Note however that the hoe hydraulics should be OFF for best output of any gear range. If the hydraulics are still flowing to the hoe it could substantially effect the H range gear, adversely. Most users hardly ever use the H range, except for road travel; dirt or otherwise. Think of it as high, NOT fast.
Have you verified the HST fluid level? What's the color of the HST fluid? How many hours on the machine? It could need a fluid change if its got high hours, or at least both HST and other hydraulic filter change(s), and fluid top off.
Is the power to the backhoe hoses shut off at the lever for A and B hydraulics when the hoe is disconnected? If the HST fluid to the hoe connections is active this will deadhead the hydraulics, and make more noise than if they are shut off. This could easily affect the HST power to H range, especially. (The last sentence is based on the NX using the same lever setup as the DK series)- I'm not certain it does...
Report back answers to above questions.:thumbsup:
Tractor has 200 Hrs and just had the 200hrs service 10 hours ago, I had the hydraulics shut off (pretty sure) but the hoses were still connected so I'm hoping that it was just the pump working overtime that caused the loss of power I think that would prob explain it. I have it off, will test it tonight then if all goes well will remount and leave hydraulics disconnected. Hoping for the best. I have driven another NX and know it has a ton of power. Was hoping to be able to drive it 9 miles on the road to a project at my house since trailering an 81 inch wide tractor with loaded Ag tires is so much fun. Spent 15 hrs Saturday making the trip to pick it up. Got to say so far it is Awesome and glad I got it. I was thinking of getting the new DKSE but my wife didn't like the cab so found a great deal on a 2017 NX will hopefully report back tonight
So I decided to check the hydraulics even though it just had its service and they were pretty low, don't know how low but the backhoe and grapple work fine so maybe low enough that it affects high gear, won't test again before adding any. I'll call the dealer and see if they remember checking, they were supposed to replace per the receipt. Hopefully that is what is causing the low power, I have driven maybe 2-3 minutes in High during my testing.
/ Kioti NX Backhoe/ HST Question #14
I suggest getting a short hydraulic hose made up, possibly by your dealer, to couple the two fittings that go to the hoe's hookup. This way when you disconnect the hoe you put the 'loop' section between the female connectors on the tractor and deadheading is no longer an issue.
And if you have a lever like the DK's have, you can hear the sound deadheading makes if you haven't put the lever to neutral, (so it is not allowing fluid to flow to either A or B rear valve(s)). You do NOT want deadheading - it WILL burn out your pump!! :irked:
The short hose is to prevent accidentally deadheading the pump when doing something with the hoe off the tractor. Maybe your dealer will make one up for you since they missed topping up the hydraulic fluid.
One way or another get it topped off with the proper fluid with wet brake capability included. Check it and oil everyday until both are full consistently.
/ Kioti NX Backhoe/ HST Question #15
I's fine, they all work that way. I have a new DK4210SE Cab and it will barely move at first in high gear but low and Med are fine, to use high gear you need to be on a perfectly flat place, mine will not go up any incline at all in high. HST's are not like a car where in a car you push the "gas" to go faster a hydrostatic works differently the less you push the "gas" the more power you have. So when your in low gear and the peddle is just lightly pushed that's max power (max work) when you floor it - you stall it or it bogs down. Same as traveling in hight gear, you need to start out easy on the peddle to coax it along gradually pressing harder as it allows you to. More peddle means more bogging down, took me 4 years to find this out - and I learned it here and it is true - I had a Kubota B2610 and I could drive it a bit in hight but it was much easier to use medium and not worry about babying the peddle, I was real worried when I bought my new Kioti but I learned to get around it - hope this helps.
2011 Chevrolet Express 2500 Cargo Van (A64556)
2011 Chevrolet...
2011 HEIL TRAILER (A65643)
2011 HEIL TRAILER...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
2015 C&M TRAILER 14 ENCLOSED CARGO TRAILER (A65643)
2015 C&M TRAILER...
Kinze Planter Tire (A65640)
Kinze Planter Tire...
John Deere Silage Wagon (A65640)
John Deere Silage...
