Traction Kioti NX 4510 only drives backwards
   / Kioti NX 4510 only drives backwards #1
Kioti4510
Spain
Kioti NX45101
Hello All,
I have my Kioti NX4510 HST now for a month and all went well.
But since I washed it yesterday after work, I can only drive reverse and not forward!!
How can that be? It was working in the field very good.
Any thoughts on this?
   / Kioti NX 4510 only drives backwards #2
Sounds like you got water into a wiring connector. I'd look around for a connector that goes to that travel pedal (forward), disconnect, dry out (and maybe apply some dialectic grease) and reconnect it.
   / Kioti NX 4510 only drives backwards #3
On my Kubota the HST controller is under the Operator's Station. There is one solenoid for reverse, a second solenoid for forward. I speculate electric wire has pulled off forward solenoid, connection is not tight, or there is dust/water in the connection.
I had wire pull off reverse solenoid twice while Bush Hogging in jungle. I installed armor made from expanded steel screen. No trouble since.
   / Kioti NX 4510 only drives backwards #4
On the right side of the tractor you can see the wiring that goes from the pedal potentiometer to the HST solenoids. They are located near the big hydraulic filter and if you have a front end loader (FEL) you may need to look through the loader's hydraulic lines. Look here first for a loose connector or damaged wiring. If the wiring looks to be intact you could have a Forward Relief valve sticking open but on such a new tractor this would be unlikely.
As I thought about this some more, I am thinking you could also have a servo spool that is just a bit sticky and will free itself by just alternately pressing the forward and reverse pedals a few times. It may help to rev the engine up while doing this and move the range lever through its positions as well.
Every once in a while my HST does the same thing, it won't respond to one or the other pedal input when I've selected a different range, but the condition only lasts a few seconds.
   / Kioti NX 4510 only drives backwards #5
AWSUBIE: Great post. I hope you continue to contribute.
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A55315)
2-Row Peanut...
2022 New Holland C327 Compact Track Loader (A55315)
2022 New Holland...
2012 International Derrick Digger (A55973)
2012 International...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2011 Toyota Camry (A55758)
2011 Toyota Camry...
2017 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
