Kioti NS310H HST Transmission Filter?
   / Kioti NS310H HST Transmission Filter?
FWIW, the HST filter (yellow) is marked with the text "Replace at 50 hours, and then every 200 hours". I also replaced the larger black one, which, be prepared for a nightmare of a job. It was tighter than about any filter I've ever experienced and you get about 1" of freedom of movement without removing the rear wheel. I had to use long-handled cloth-strap style wrench typically designed for separating pipe parts.
   / Kioti NS310H HST Transmission Filter? #12
My NX4510 HST also takes the TD24-0257a filter. Can some genius cross reference to Fram etc? Its out of stock everywhere.
Update: my dealer let slip it matches Donaldson 169078. I'm gonna try that because its $39 instead of $133.
   / Kioti NS310H HST Transmission Filter? #13
Did you ever try the Donaldson Filter 169078 to replace the kioti TD24-0257A filter? I'm kinda in the same boat right now!
New Land Honor Heavy Duty Plate Compactor (A59000)
New Land Honor...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2018 FREIGHTLINER...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2014 GENIE Z-60/34 BOOM LIFT (A52709)
2014 GENIE Z-60/34...
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
MASSAGE CHAIR (A58214)
