Kioti Mechron PS cigarette lighter a usable power point?
   / Kioti Mechron PS cigarette lighter a usable power point? #1
Rod in Forfar
Platinum Member
Forfar, Ontario, Canada
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
For many hours I ran a 12v pump spraying weeds with my Ranger TM until the thing quit charging altogether. Turns out the Robin 18 hp engine had a magneto rather than an alternator, and it couldn't take the sustained use.
My 2020 Mechron PS has a proper alternator. Is it safe to use the cigarette lighter as a power source for a 25 gallon sprayer mounted in the bed? Up until now I have just tossed an old 12V battery into the back and connected with alligator clips, the way I did on the Ranger, but a permanent solution might be nice if the Kioti can generate the power for a couple of tankfuls per day as I water the garden.
Rod
   / Kioti Mechron PS cigarette lighter a usable power point? #2
Check the fuse - cig liters usually 15 amps, power ports 10 amps these are handy if you can find them
From Amazon I ordered a 15 amp plug with 5' cord which has the correct quick connectors coming off the pump. I'll give it a try when it arrives, but in the meantime I have recharged the shop battery for another summer watering the garden.
   / Kioti Mechron PS cigarette lighter a usable power point? #4
I use the cigar lighter (power port) on our Kubota Sidekick to power a bed mounted sprayer all the time with no issue.
I took your advice and dumped the spare battery and charger in favour of the cord from the power outlet on the Kioti. Daily output of water to the garden has crept up to four, 25 gallon tanks per day as a result. The hours are creeping up on the Mechron, but that is the only issue.
2022 JOHN DEERE 318G SKID STEER (A52707)
2022 JOHN DEERE...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A57024)
GMC 3500 Extended...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2016 CATERPILLAR 930M WHEEL LOADER (A52707)
2016 CATERPILLAR...
1328 (A57192)
1328 (A57192)
40006 (A55788)
40006 (A55788)
