Kioti Mechron 2200 12v power outett (cigarette lighter plug) problem
   / Kioti Mechron 2200 12v power outett (cigarette lighter plug) problem #1
srusse
Central Louisiana
Kioti Ck30HST FEL, Mechron 2200, Grasshopper 325A ZTR
My 2015 Mechron 12v lighter plug suddenly lost power. Trouble shoot shows no 12v arriving at the plug. I can find no fuse/ckt breaker that seems to be associated with this item. Anyone have knowledge of where there might be a fuse or a possible solution? I use the plug to power my 15 gal sprayer.
   / Kioti Mechron 2200 12v power outett (cigarette lighter plug) problem #2
My 2017 CK4010 (cab tractor) had no (constant)power to the dome light or radio harness.
Apparently there is a water intrusion problem in the harness plug under the tractor below the left side step.
The water entering and trapped in the plug doesn't play well and corrodes the pin on the red constant power wire in the harness connector.
Kioti provided a kit to reposition the plug so water drains from it to eliminate the electro / galvanic corrosion.
Your tractor doesn't have a factory cab and is a little older, but I'd trace the red (always hot) wire back to the plug and check for voltage at the plug.
Your dealer can have Kioti email them a wiring diagram and location of the plug.
Kioti factory dealer support (from South Carolina) is excellent, as long as your dealer service advisor is willing to work with them (and you).
   / Kioti Mechron 2200 12v power outett (cigarette lighter plug) problem #3
My guess is, your over loading that plug, I'd make sure the wire to it, is heavy enough for the amps you are drawing.
SR
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
John Deere 8400R MFWD Tractor (A53342)
John Deere 8400R...
Pallet Fees (A50775)
A1 MIST SPRAYERS RESOURCES TX3PT LOT NUMBER 85 (A53084)
A1 MIST SPRAYERS...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
