Kioti Loaders vs Kubota
   / Kioti Loaders vs Kubota #31
For the numbers to be skewed that much, ALL Kioti owners registered on TBN would have to post all of their problems and only 10% of the Kubota owners would be posting their problems.
I for one think that perhaps Kioti owners, on this forum anyway, would be more inclined to go to the dealer before turning a wrench.
I don't think anyone disputes that the proportion of activity on the Kioti forum is way out of proportion to the number of tractors (especially compared to Kubota). I think that does indicate that there is a somewhat different group of people owning Kioti's. I'd imagine (and recommend) that folks who don't want to pick up a wrench would buy from an established dealer most of whom sell either Kubota or JD. I don't remember the estimates exactly but I am pretty sure that Kubota outsells Kioti by about 20-1 at the very least and probably more like 50-1. Given that at this moment there are a total of 23746 posts about Kubotas and 4325 posts about Kiotis, (ratio of only 5:1) I'd say that the Kioti community is disproportionately represented here. As TBN tends to attract do it yourself types, that might argue that they do more service/maintenance themselves than the typical Kubota owner. Of note, I checked on the ratio of Buying/Pricing to Owning/Operating posts for each brand. They are identical 69% of posts are about owning or operating which is where discussions on problems and service tend to occur. One might hypothesize that if Kioti owners were having much more trouble with their machines that those ratios would not be the same. However it is really not possible to answer the question from self reported issues especially since a lot of the posts are about exactly the same issue...(do I need to mention loader cracks? :D).
No one is suggesting that Kubota is not top of the hill in sales and I believe also in quality. The question is how much are you willing to pay extra for that last increment of quality. If a Toyota cost the same as a Hyundai I'd buy the Toyota. If it cost a third more then I'd look real hard at that Hyundai to see if it met my needs. That is how Kioti is building their business.
By the way, I just used the Kubota pricing tool to get a "quote" (not from a dealer so this is list price) for a setup on the L3940 that is virtually identical to my DK40se/FEL by adding a rear remote, quick attach loader, draft control and one extra year extended warranty to the Kubota/FEL. The list price of the Kubota set up was a few bucks shy of $31,500. The list on my DK40se set up two years ago was a solid $6000 less. That range price differential (and much stronger loader:)) is what allows Kioti/Hyundai to steadily gain ground on Kubota/Toyota even when Kubota/Toyota has some undeniable advantages.
   / Kioti Loaders vs Kubota #32
That is one one of looking at it. Of course, the other way of looking at it is how much will that small increment of quality will cost you over the lifetime of the machine?
   / Kioti Loaders vs Kubota #33
Back to loader specs:
My experience looking at both brands in similar weights is Kioti tends to design with a little more lift capacity and Kubota tends to have better curl on the bucket. Kubotas seem to design for a bit more reach too but it can be clumsy in tight quarters. The flow numbers listed are meaning less except for evaluating cycle times. They don't affect the weight capacity.
Second, both companies underrate their loaders in a sense. Kubota used to publish the capacity chart for the entire lift range but it is now found only in the manual. Both companies give you one pressure and to the max height.
Both companies tend to have the reliefs set a bit light so there is room to shim for more capacity.
Both companies far exceed the capacities Deere provides in a similar weight tractor.
I know some people shim their Kubotas up to much higher relief pressures but they will risk bending the lift cylinders lifting too much to full height with the cylinders fully extended. I know I could use a bit more omph for moving pallets only a few feet off the ground but it (LA852) will already lift almost double its rating a ground level which is load enough on the front axle.
   / Kioti Loaders vs Kubota #35
This was posted in another Forum on TBN but ties into this exact discussion.
If you've never looked into the Kubota dilemma, I'll tell you that the FEL capacity is a huge factor when it comes to whether you'll keep your tractor. Don't get caught climbing the Kubota ladder!
Posted by 'Punk' (TBN handle)
Don
   / Kioti Loaders vs Kubota #36
Hey Art... have you ever had in any of the Jimma backhoes that you can find online. Let me tell you... I could not in good conscious sell that kinda stuff to anyone.
I have had a couple of lines, a lawn mower company to boot! They will paint them my colors as well as my name on them! I sent them packing, didn't want my name on products like that!
A fellow north of me trying to get into the tractor business did start selling them with his name on them in 03. He does have a different attitude of business then we do. He likes them coming back because of lower quality. In 08 for personal use he bought a Kubota! Kind of says it all!!!!!
There are people that are going to buy that type no matter what we say or do. There is a seat for everyone in the house!
   / Kioti Loaders vs Kubota #37
It is quite a bit different for someone sitting on the side who owns one make of tractor at a time maybe two and knowing what he does with it raving about how good it is when they might not even be working it to it's fullest.
When you compare that person to someone who might be around twenty plus differnet tractors a day of all makes and models. I think that there is a bit of difference! Some of our customers are trying to do with a thirty horsepower when they should have a fifty horsepower tractor for.
We've had differnet makes and models sold around us for years, I've heard the claims of the dealers, "they are all the same, just get the lowest price",( a retired insureance agent who wanted to be a dealer) and a lot more even one with the kioti's that they were the same as Kubotas just less money!(that was before we were dealer for them). At the time we only sold the IH line-up. Today we sell three brands of compact tractors.
It is always fun listening the the customers problems. Having to remedy them of their problems is our challange. We have a few of every make in our area, some new, some old, we take them in trade from time to time. I can't think of a make that hasn't been in our area although some haven't been in our shops yet but it's always interesting to talk to the owners.
I've seen help that didn't like a particular tractor work very hard to destroy it....
I've seen them try and cover the major failures of the ones they like. From the mouths of the babes, we often learn the truths. Pride can be a winner or a looser.
I watched the color blind as well as tried to deal with them.
I've seen a lot in the years I've spent at the dealership.
I do know what we see a lot of in the shop, and can compare it to the designs that are working!
I can look at a lot of things and predict failures on new machines being introduced. I've seen some things that I thought would fail, do fine with the right owner. I can see the trouble spots that the techs won't like in five to ten years.
I see people who want to keep a machine till they quit livin' I see people that with the next bell and whistle they are on the phone to buy.
I've seen machines come and go, can't even give the total numbers in the thousands somewhere is all.
I'm a machinery junkie myself, my wife wants me to retire, I told her no way, to me I live in an adult boy toy store! This is my life.
I still maintain there is no one seat for every butt, but don't look with your eyes closed!
How many hours are you spending with tractors today?
Yes, Art. We all know you are a dealer with years of experience and qualifications. But, you still haven't substantiated your statement. Given that you are a dealer, both qualified and experienced, tell us how you justify explicity saying that one brand (the implications is Kioti in this instance) will yield 3000 hours of service while a similar Kubota will give 10,000 hours. I'd really like to know how you derived these numbers. Working as a dealer for x years, hanging out around tractors all your life, simply aren't specific enough for such specific proclamations.
If you can't substantiate it, then it's truely irresponsible for an experienced, qualified dealer to make what is seemingly an outrageous claim. A consumer says it, yeah we take it with a grain of salt. An experienced, qualified dealer such as yourself, it carries much more weight. Defend your brand. State true facts. Toot your horn all you want. But, please refrain from extreme exagerations disguised as facts from a "reputable" source. There are a lot of gullable newbies on here that might just buy into such distortions.
You've been around and associated with the sales and servicing of thousands of tractors. This I don't doubt. What I do doubt is that you've seen more than a handful of CUTs with 3000+ hours, regardless of brand. And 10,000 hours on a CUT.... well that's just outrageously rediculous.
On the difference in the number of problems posted: Many things can, and probably do, influence the data. For instance, it would be interesting to know the breakdown of tractor make/models purchased by age group. I strongly suspect that TBNers are younger owners than non-TBNers. I also suspect that older buyers will tend to stick with the tried and true, or what they have grown up with rather than try a second tier brand. Older buyers might also have more disposable income where price is less important. This assumed large group of non-internet owners of premium machines would drastically skew the data. It's really difficut (maybe impossible) to quantify the percentages based just on TBN postings. However, I do think the general statement still holds and is indicative of quality: Kubota and Deere report fewer problems. Trying to quantify it any more than that is just not credible.
   / Kioti Loaders vs Kubota #38
I can't comment on the lifespan of the Kioti tractors, most CUT's with high hours don't seem to get top notch maintenance as they live with busy landscaping companies and they live anyways.
Most problems I see on here are dealer setup issues rather than quality control but Kioti and Kubota both have had some design issues in the last few years. Kubota has struggled with trying to make econo 3 pt hitches, Kioti had some axle and front loader issues. We aren't gonna solve any arguments about it because neither company is going to release stats on repairs.
   / Kioti Loaders vs Kubota #39
I don't know if they need to worry about longevity, the average is 50 to 100 hours a year.
About ten a year on the average at 3000 plus hours, the 10,000 is only once in a great while. They might die on the farm and be buried with out the service. We do have tractors in our area that area are well over 10 and 20 thousand hoursas well as one that I know of over 30,000, not the kubota's, wait a couple more years!
A few years back, was working with a couple of different reps from differenet companies, it's amazing as to what the differences was on like machines and the amount of warantee dollar allowance per unit per brand. took it a little further and found that some lawn mowers were higher then a tractor!
The number of the trades, the perspective customers wanting to trade different makes, and listening to the customers as to WHY they want to get a new tractor and switch brands, and for those out there in our area that we are working on.
We have several BX's at 5000 plus hours at this point and it is not uncommon at all to see the larger Kubotas M-series in the five thousand plus hour range on farms and some just getting into the ten thousand hour mark
I have a B 6200 in stock right now that by the 100 hour oil changes is well over three thousand five hundred hours by his log. Was owned by a xmas tree farmer with over 17,000 tree's to mow between them(he's in retirement now with the 17,000 tree's)
I've had F-series 2400's come in from golf coarses that were over 10,000 hours with the original decks, hydro's and engines never touched, still working today.
For the customers that do trade from deere or the CNH line we see where with other makes the trade cycle is often moved from 1000 to 1500 hours to 2500 hours plus when switching to the Kubotas. These are commercial accounts that can't afford to be down at all.
the kioti's I've had in were all around the 1,000 hour mark as well as a few other makes like belarus with some of those hitting up to 3000 hours, my thoughts were figuring the problems when traded, how long did they have to go! Valve jobs at two thirds time before engine rebuild just general things from past experience.
The whole thing is initial build quality, Kubota attachments to the tractors don't need to have the wholes egged out a bit to get the bolt in while being asembled and they are not elongated to fit from the factory like some I see on brand new tractors. The controls I call generic for the most part, just like many other compacts, not something that is industry unique, on the models with the bells and whistles, we don't seem to have problems with those! The Kubota do offer a great amount variety of models with some being the same horsepower repectfully although they offer three different chassis's.
I learned a long time ago that many of the larger more commercial farms and landscapers although the operator might be rough, the day to day operations get the machines more maintenance then many home owners or small commercial accounts which do use us more for repair.
There are many studies that give us the break downs of who buys and why. They are not the same from one area to the next!
It's hard not to find a Kubota to fit!
It would be great to be able to show everyone here what we've found working on all the different makes.
I still doubt that it would change but a few for buying habits! Some still would not understand.
Besides, some people need to work on their tractor so why buy one that doesn't give an excuse to go to the man cave and have a cold one.
   / Kioti Loaders vs Kubota #40
I have a kubota and my excuse yo go the the man-cave and drink a few is to wash and wax the ol' girl.:D And maybe a little touch-up paint in the high wear areas like operator platform.
72'' power rake (A53421)
72'' power rake...
12in Digging Tooth Bucket Excavator Attachment (A55787)
12in Digging Tooth...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2016 CATERPILLAR 259D SKID STEER (A52705)
2016 CATERPILLAR...
2012 Volkswagen Passat Passenger Car, VIN # 1VWCN7A38CC043906 (A55758)
2012 Volkswagen...
