kioti lk3054 steering mystery solved
   / kioti lk3054 steering mystery solved #1
ltdowns
EADS
lk3054
I have had several replies kubota is not like a Kioti. Here is what I just did to repair my Kioti lk3054 steering column leak. I searched everywhere looking for Kioti column parts breakdown and it is not correct. If you look up Kubota l2050dt it is the exact diagram of my column. I went to Kubota and bought seal for the bottom of column as well as o ring. They are the exact parts I needed.If you lookup kubota steering assembly and get part number and search part number under Kioti it is the exact same number for Kioti.Hope this helps someone else out there.
   / kioti lk3054 steering mystery solved #2
That's interesting Thanks for posting
   / kioti lk3054 steering mystery solved #3
Thank You your post is very helpful.
   / kioti lk3054 steering mystery solved #4
FYI Kubota L2550dt has the same engine...have used kubota rings and water pump seal for my LK 3054, working great!
(APPROX 100) UNUSED FUTURE 10' GALVALUME STEEL (A51248)
(APPROX 100)...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
(APPROX 20) 3" X 4" X 21 7/8" TUBING (A51247)
(APPROX 20) 3" X...
UNUSED CFG INDUSTRIAL QK16R EXCAVATOR (A51247)
UNUSED CFG...
Peterbilt 377 Semi-Truck (A53472)
Peterbilt 377...
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
