kioti lk3054 steering mystery solved
   / kioti lk3054 steering mystery solved #1
ltdowns
EADS
lk3054
I have had several replies kubota is not like a Kioti. Here is what I just did to repair my Kioti lk3054 steering column leak. I searched everywhere looking for Kioti column parts breakdown and it is not correct. If you look up Kubota l2050dt it is the exact diagram of my column. I went to Kubota and bought seal for the bottom of column as well as o ring. They are the exact parts I needed.If you lookup kubota steering assembly and get part number and search part number under Kioti it is the exact same number for Kioti.Hope this helps someone else out there.
   / kioti lk3054 steering mystery solved #2
That's interesting Thanks for posting
   / kioti lk3054 steering mystery solved #3
Thank You your post is very helpful.
   / kioti lk3054 steering mystery solved #4
FYI Kubota L2550dt has the same engine...have used kubota rings and water pump seal for my LK 3054, working great!
New/Unused 7ft 10 Drawer Work Bench (A51573)
New/Unused 7ft 10...
2014 Caterpillar 289D High Flow Compact Track Loader Skid Steer (A51691)
2014 Caterpillar...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
