Kioti LK3054 mystery part in valve cover
   / Kioti LK3054 mystery part in valve cover #11
It is definitely part #10 as Ritcheyvs pointed out. I just recently tore down my engine for rings, head gasket, etc. It is used only under the #1 cylinder rocker arm " stantion " which fits into an oil supply port, I assume this is an orifice setup for rocker oil supply. Don't have a clue how it got out though!
   / Kioti LK3054 mystery part in valve cover #12
It is definitely part #10 as Ritcheyvs pointed out. I just recently tore down my engine for rings, head gasket, etc. It is used only under the #1 cylinder rocker arm " stantion " which fits into an oil supply port, I assume this is an orifice setup for rocker oil supply. Don't have a clue how it got out though![/QUOTE
I thought that was what it was for. I just haven't seen a metering jet in one before.
It was the screw holder mentioned above. Thanks everyone for the help.
1998 CAT 140H Motor Grader (County Owned, Cat Maintained) (A59213)
1998 CAT 140H...
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
New/Unused AGT Industrial QHT500FL Mini Tracked Dumper (A57453)
New/Unused AGT...
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
2017 Kubota L3560 (A57148)
2017 Kubota L3560...
(INOP) CATERPILLAR PS-130 PNEUMATIC ROLLER (A58375)
(INOP) CATERPILLAR...
