Kioti Lk3054 hydraulics quitting intermittently
   / Kioti Lk3054 hydraulics quitting intermittently
Havent had a chance to use it much but so far it hasnt quit again,,but it didnt quit until I had used it a for few hrs,,havnt ran it that long since I changed the filter
   / Kioti Lk3054 hydraulics quitting intermittently #12
Keep us informed. If you have more issues and it turns out to be the pump, I posted detailed instructions when I upgraded mine. Pretty simple to do but hopefully you have it going.
   / Kioti Lk3054 hydraulics quitting intermittently #13
Before you spend a lot of money, if you have intermittent problems, could be air in the suction line. There is a rubber connector (6" long) in the suction line from the back of the tractor to the pump. We have seen this rubber connector get hard and crack over time, especially at the 2 hose clamps. It doesn't have to leak to be able to suck air and cavitate the pump. Just a simple check before spending a lot of time and money. We have seen this on several older LK3054 Tractor.
Hope this helps.
   / Kioti Lk3054 hydraulics quitting intermittently #14
Could this be a relief valve acting up?
   / Kioti Lk3054 hydraulics quitting intermittently #15
Hopefully the filter was the issue!
I agree that rubber connector can be a problem, I just changed mine last week that I ordered from Michigan Iorn.
I never had a issue with the pressure relief but it certainly could be a problem. But if the problem still exists, I would look very closely at that pump.
   / Kioti Lk3054 hydraulics quitting intermittently #16
Hope this helps.
Could this cause intermittent steering failure? Happens once in a while especially when I'm bush-hogging, steering stops responding. Turning the wheel back & forth a couple times "fixes" it. Only affects steering, not FEL.
Where is this hose, is it easily accessible?
   / Kioti Lk3054 hydraulics quitting intermittently #17
Yes, this could be a cause of steering loss. Could be other issues as discussed here, but air in the system can be a cause.
The rubber connector is near the bell housing behind the pump. Follow the suction line from the back of the tractor along the right side, you'll find the connector near the bell housing.
Hope this helps.
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
2016 KENWORTH T800(INOPERABLE) (A58214)
2016 KENWORTH...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND69FDGH1752 (A57453)
2015 Freightliner...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58216)
TOOTHED BUCKET...
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
