KIOTI LK 3054 clutch adjustment.pto
   / KIOTI LK 3054 clutch adjustment.pto #1
hitts427
chesaning Mi.
kioti lk 3054
I'm having a hard time engaging my pto.I've heard that this is a two stage clutch.When I press clutch pedal down to engage the pto it grinds and won't go in.I end up turning tractor off put the pto in gear then start machine to run my mower.Any help would be appreciated.Hoping for a manual for fathers day.Thanks Ken
   / KIOTI LK 3054 clutch adjustment.pto #2
The clutch linkage is adjustable...it's under the left footrest. There is an inspection plate on the right side of the transmission. You want ~.010-.012" clearance between the clutch fingers and the throw-out bearing. I used a long piece of metal of correct thickness as a "feeler gauge", since the bearing is a good 8" in, and I was afraid of dropping a regular feeler gauge down inside the transmission. Don't go by pedal freeplay alone.
BTW, the manual has it backwards as to which way you adjust the linkage to increase/decrease free play. If I'm not mistaken (it's been a couple years since I've adjusted it) lengthening the rod decreases the freeplay.
Thank you.I will check it out.Ken
I didn't have any luck with adjusting pedal free play.Still grinds going into gear.(pto)So now I will have to go into the side cover to adjust pressure plate.I've heard that with the loader mount on this isn't an easy job to do.Do I need to remove the loader mounts?
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A53472)
Toyota 6FGU25...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
