Kioti lb1914 Tractor
   / Kioti lb1914 Tractor #1
agman5735
My hydraulics are not working. The 3 point will raise if RPM's are raised.With no implements hooked on the 3 point. But will not raise at an idle.
I have taken out the filter and seems to be okay. Also removed the plug on the front of the pump with engine running but very little fluid comes out. Seems that with this test ,fluid should be under pressure and shoot out. What has been anyone's experience with this problem. Thanks
   / Kioti lb1914 Tractor #2
Mornin Agman,
Im not familiar with your tractor but my first thought is that you have a damaged hydraulic pump, key sheared etc... You need to get a service manual for that machine, check hydraulic pressure etc... But thats what it sounds like to me, there are a bunch of guys that own that tractor that can offer more help ! Good Luck!
BTW welcome to TBN !
Thanks i have a manual coming. Where is the suction screen located. agman
   / Kioti lb1914 Tractor #5
Does the 1914 have the little valve behind your heel just under the seat? My CK 20 does. If this gets bumped, it can cause your symptoms.
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2020 John Deere 260E Off-Road Dump Truck (A50322)
2020 John Deere...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2015 Ford F-550 Auto Crane 4004EH 4,000LB Crane Service Truck (A51692)
2015 Ford F-550...
LOT LOCATIONS (A52141)
2014 John Deere 644K Articulated Wheel Loader (A50322)
2014 John Deere...
