Kioti LB1914 problem tractor wont move.
   / Kioti LB1914 problem tractor wont move.
Problem solved. Unfortunately after splitting the tractor and finding everything looking good we found the 4WD lever had been bumped slightly out of gear. It is kind of stiff shifting. Once it was worked back and forth several times it engaged and the tractor now works as it should.
Embarrassed yes but glad to have it back to work.
2021 Delta Redirective Crash Cushion 75000 (A49461)
2021 Delta...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
2000 KOMATSU VALMET 860.4 FORWARDER (A51222)
2000 KOMATSU...
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
