kioti lb1914 hydraulics
   / kioti lb1914 hydraulics #1
jwillis8
How full do you fill the hydraulic oil on lb1914--no manual:confused:
   / kioti lb1914 hydraulics #2
Is there a dipstick or sightglass?
sight glass far down on the side but seems too low to be the functional level?
   / kioti lb1914 hydraulics #4
There is a red plug directly below the front of the seat on the transmission that screws in.
   / kioti lb1914 hydraulics #5
Repost from last. Got sent before I finished. The manual says the fluid level should be half way up in the sight glass. Below is quoted from the owners manual:
Hydraulic/Transmission Fluid Level
The tractor hydraulic/transmission and differential fluid use the same reservoir. The fluid is contained in the transmission housing. When inspecting this fluid level, be sure that the hydraulic cylinder(s) are in their normal position with implements resting on the ground. The fluid is most accurately checked before operating the tractor while the fluid is at room temperature.
To check the fluid level, the 1914 has a view windoe on the right side of the transmission (close to the brake pedals). The fluid should show between the marks as indicated in the window (appox 1/2 the window)
The manual specs the following fluids:
Multi-grade Trans fluid
Chevron---Tractor hydraulic fluid
EXXon--Torque fluid 56
Mobil---Mobil Fluid 350
Pennzoil--Hydra-Tranz and wet brake
Quakerstate--Tractor hydraulic
Shell--Donax T-4
Texaco---TDH oil
Union----Hydraulic/tractor fluid
Valvoline---Unitrac
Thanks--exactly what I needed. john
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52748)
2015 Ottawa Yard...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
