Kioti LB1914 Hyd Pump Question
   / Kioti LB1914 Hyd Pump Question #11
Your tractor would be a '95. It is possible for your tractor to have many more hours and still only show what you have if the previous owners disconnected the tach cable or if the tach cable broke and they never replaced it, except for when they sold it. I would check for air leaks as another member checked. If your tractor is that old then it would be a good idea to go ahead and check all fittings and replace that rubber pipe by your filter.
The new LB1914's have a hyd pump of 6.0 GPM which should be same as yours.
I would check the hyd pressure of your tractor and see what you get.
   / Kioti LB1914 Hyd Pump Question #12
What determines the year? Is it the 1st digit or letter? If so, mine starts with a "D" does that mean it was built in 04?
   / Kioti LB1914 Hyd Pump Question #13
Check your filter it sounds like it is not tightly sealed
   / Kioti LB1914 Hyd Pump Question #14
correct... if it is a nine digit SN# then the first digit (or letter) is the last digit in the year. they started this system in 1994 so anything older than 94 is an 8 digit number, and you have to get ahold of Kioti for an approx year.
   / Kioti LB1914 Hyd Pump Question #15
Just wondering if you ever solved your problem, I too have a LB1914 and I always wondered whether I could adapt a larger Hyd. Pump on it to speed up the loader functions without having to rev the engine so much! Has anyone ever done this?? /forums/images/graemlins/confused.gif
   / Kioti LB1914 Hyd Pump Question #16
I would like to add a front loader to a LB1914 4x4 Kioti. Where would I attach the hydraulic lines? Would a Kubota hydraulic pump that runs off the front of the crankshaft work? thanks, gregjo1948
   / Kioti LB1914 Hyd Pump Question #17
Gregjo, Way way better to start a new thread instead of hijacking a 6 year old thread… All the best with your project.
   / Kioti LB1914 Hyd Pump Question #18
"Hijacking" seems a bit harsh but, I will repost on a new thread.
   / Kioti LB1914 Hyd Pump Question #19
Not sure what else you’d call it? Just trying to help. Someone that’s had the Same issue might not become aware of your issue otherwise…
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A55314)
2023 Unverferth...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
2010 Toro Workman MD (A55973)
2010 Toro Workman...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
Electric Mobility Scooter (A55853)
Electric Mobility...
2013 TAKEUCHI TB235 EXCAVATOR (A52707)
2013 TAKEUCHI...
