Kioti LB1914 bevel gears
   / Kioti LB1914 bevel gears #1
drosenkrantz
Nephi Utah
Kubota, Kioti
Hello all. I am replacing the seals on the front axle of a kioti LB1914. I have replaced the seals, but cannot get the gears to mesh properly. I might have the bearings in upside down or something. There are some shims on the bottom plate and I have installed them like I found them. I looked online at the parts diagram, but it the did not show if the bearings are upside down or not . Can anyone help on this? Thanks drosenkrantz.
I have found that I was trying put the shaft upside down. ( Duh ). Leaks are gone, and life is good. When you get old, 2 weeks between the tear down and rebuild is a whole new process. Thanks Dave rosenkrantz.
   / Kioti LB1914 bevel gears #3
At least you got it.
That's what counts.
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
New Long Forks (A53002)
New Long Forks...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
