Kioti LB1914 bevel gears
   / Kioti LB1914 bevel gears #1
drosenkrantz
Nephi Utah
Kubota, Kioti
Hello all. I am replacing the seals on the front axle of a kioti LB1914. I have replaced the seals, but cannot get the gears to mesh properly. I might have the bearings in upside down or something. There are some shims on the bottom plate and I have installed them like I found them. I looked online at the parts diagram, but it the did not show if the bearings are upside down or not . Can anyone help on this? Thanks drosenkrantz.
I have found that I was trying put the shaft upside down. ( Duh ). Leaks are gone, and life is good. When you get old, 2 weeks between the tear down and rebuild is a whole new process. Thanks Dave rosenkrantz.
   / Kioti LB1914 bevel gears #3
At least you got it.
That's what counts.
Cat TH407C Telehandler (A53472)
Cat TH407C...
Sears/Craftsman Shredder (A51573)
Sears/Craftsman...
2015 International ProStar Truck, VIN # 3HSDJSNRXFN563873 (A51572)
2015 International...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
2025 New/Unused Wolverine Mini Ripper (A51573)
2025 New/Unused...
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
