Kioti Lb1914: adding a Loader?
/ Kioti Lb1914: adding a Loader? #1
FishtheRainy
Baudette, Minnesota
Kioti Lb1914
I purchased a used Lb1914 and I am thinking about adding a loader to the tractor. It looks like there are several brands that may fit; how difficult would it be to install one?
/ Kioti Lb1914: adding a Loader? #3
Why not get the Kioti loader that was made for it? That would make it a little easier as all the hardware would be ready made for it. I'm fairly sure you'll at least need one helper, but it shouldn't be real hard to install.
John
Oh, sorry, I meant to welcome you to the forum! KJ
/ Kioti Lb1914: adding a Loader? #4
John
I certainly could purchase one made by Kioti; my main problem is that I am located several hundred miles from the nearest dealer. But you are correct in that a Kioti loader may be the easiest to instal, besides I would probably have to have it shipped here anyway.
/ Kioti Lb1914: adding a Loader? #7
Check with anyone that sells Woods Equipment and find out if they have one made for the Kioti. They have made quite a few for Kioti models, but I'm not sure they have one for yours.
John
/ Kioti Lb1914: adding a Loader? #8
John
/ Kioti Lb1914: adding a Loader? #9
Might see if you have a Rhino dealer near by.... They use to be the supplier for Kioti.
They are very easy to install and 1 guy can do it.
Send me a message if you have any questions....
/ Kioti Lb1914: adding a Loader? #10
/ Kioti Lb1914: adding a Loader? #11
FIll in your profile and let us know where you are. It would be easy to get the Kioti Loader for that tractor.
/ Kioti Lb1914: adding a Loader? #12
/ Kioti Lb1914: adding a Loader? #13
</font><font color="blue" class="small">( Might see if you have a Rhino dealer near by.... They use to be the supplier for Kioti. )</font>
Good one. I should have thought of that! Will probably be less expensive than a Woods also.
John
/ Kioti Lb1914: adding a Loader? #14
John
2021 JOHN DEERE 304L WHEEL LOADER (A65056)
2021 JOHN DEERE...
PALLET OF MISC SIZE STYLED JACKS (A67714)
PALLET OF MISC...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
5HP CNC END MILL (A68842)
5HP CNC END MILL...
CAT J600/375L Teeth (8) (A68134)
CAT J600/375L...
2015 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2015 Autocar...
