Kioti Lb1914: adding a Loader?
   / Kioti Lb1914: adding a Loader? #1
FishtheRainy
Baudette, Minnesota
Kioti Lb1914
I purchased a used Lb1914 and I am thinking about adding a loader to the tractor. It looks like there are several brands that may fit; how difficult would it be to install one?
   / Kioti Lb1914: adding a Loader? #3
Why not get the Kioti loader that was made for it? That would make it a little easier as all the hardware would be ready made for it. I'm fairly sure you'll at least need one helper, but it shouldn't be real hard to install.
John
Oh, sorry, I meant to welcome you to the forum! KJ
   / Kioti Lb1914: adding a Loader? #4
John
I certainly could purchase one made by Kioti; my main problem is that I am located several hundred miles from the nearest dealer. But you are correct in that a Kioti loader may be the easiest to instal, besides I would probably have to have it shipped here anyway.
   / Kioti Lb1914: adding a Loader? #7
Check with anyone that sells Woods Equipment and find out if they have one made for the Kioti. They have made quite a few for Kioti models, but I'm not sure they have one for yours.
John
   / Kioti Lb1914: adding a Loader? #8
John
   / Kioti Lb1914: adding a Loader? #9
Might see if you have a Rhino dealer near by.... They use to be the supplier for Kioti.
They are very easy to install and 1 guy can do it.
Send me a message if you have any questions....
   / Kioti Lb1914: adding a Loader? #10
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
Lift Station Pumps (A49461)
Lift Station Pumps...
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
2015 VANTAGE TRAILER CRUDE TRAILER (A50854)
2015 VANTAGE...
