Kioti LB 1914
   / Kioti LB 1914 #1
thehawkatc
No electrical power when I turn the switch, nothing, no lights on the panel. Checked battery, fuses and they are fine. Any ideas as to the problem?
   / Kioti LB 1914 #2
Check to be absolutey certain the ground is making connection at the frame.
Make absolutely sure your terminals are clean and tight.
I'd check the key switch to make sure it is functioning.
Check the battery for voltage with the key on and off.
Good luck,
Joel
   / Kioti LB 1914 #3
Check the Slow Blow Fuse on the wiring harness near the starter. Not sure when you say you checked the fuses that you also checked the slow blow fuse. It will shut you down.
If it is blown, check all the wiring harnesses for a possible short to ground.
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED FUTURE FT-XJ7T 7 TON 46" HYD THUMB CLAMP (A51248)
UNUSED FUTURE...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
