Kioti L2601
/ Kioti L2601 #1
Thud
Georgia
Cub Cadet Yanmar Sx3100
Hi all,
I am new to this forum, I just purchased a used grey market Kioti tractor it is a model L2601. By searching this board I found out that the US import model that corresponded to this one was a LB2614, which was superceded by the LK3054. Does anyone know where I can get an operators manual for this (probably not), Does anyone have any knowledge of the L2601 and know how close the LB2614 manual would be for my general use.
I was told by the guy who sold it to me that the 3 cylinder Diesel and the front end drive was the same a Kubota of some model that I don't recall at this time. Did Kubota use a Daedong engine? This is a 1992 model.
Thanks in advance for any information or links to any information on getting manual and parts for this tractor.
Ken in GA
/ Kioti L2601 #2
The only thing I can tell you for sure is that that model never used a Kubota engine of any type. There is not now, and never has been a connection between these two companies.
If you can find information on a foreign distributor of Kioti, you may be able to order a manual from them.
Try to find out where the tractor was originally meant to go. If it says Kioti and not Daedong, that should help you isolate where it should have gone. I believe the Kioti mark was only used in Europe and the US, but I can't remember for sure.
John
/ Kioti L2601
Thanks for the reply.
Near as I can figure it's a Daedong L2601 not sure where it was marketed as all the markings are in Korean I believe. It looks very simular to a LB3054, I was told that the same model was imported to the states as a Kioti LB2614 modified for US use. I will search around on the Web and maybe I can find an Australian Dealer that has Service/owners manuals for them, written in English. Any Aussie's on this Forum?
Thanks
Ken
/ Kioti L2601 #4
Thanks
Ken
Hello,
I have an identical tractor... Daedong L2601-4WD... I've been looking for parts and manuals also...
/ Kioti L2601
Hi As far as I can tell the L2601 is very very similar to the LK3054, I purchased the the user, parts and repair manual for the LK3054. There are some differences such as the Daedong L2601 has a 3 speed PTO (540, 756, 1000), and the LK3054 has an optional 2 Speed PTO (540, 1000). The 3 cylinder diesel engine is the same one and majority of the rest of the tractor is the same. It has been a very reliable tractor for me hope yours has as well.
Thud
/ Kioti L2601 #6
Hola para los que buscan informacion sobre el tractor DAedong L2601 .este fue un producto que fabricaron Kubota en conjunto con Daedong de KOREA;daedong puso la transmision y Kubo
ta todo lo demas.De manera que comentraron en pleito ninguno autoriza al otro para vender piezas.Yo las consigo en Costa Rica.FUE COMERSIALIZADO COMO Kubotta ;Modelo Daedong L2601 4 W d serie 426600009
/ Kioti L2601 #7
You could begin here: Michigan Iron & Equipment. Call them, and see if they can help steer you toward what you seek.
The guy who wrote in Spanish is saying something to the effect that Kioti and Kubota collaborated on these machines; that Daedong made the transmission and Kubota the rest of the tractor- (best my Spanish can discern...)
/ Kioti L2601 #8
.Daedong
para el tipo que duda de la demanda que le puso Kubota a Daedong( Kioti para U.S.A. ) por estar robando tecnologia segun kubota que investigue bien y lo podra comprovar.Poreso el problema para conseguir repuesto y catalagos.Si tienes el telefono de Michigan Iron & Equipment ,te lo agradezco.Kubota lo vendio como Marca Kubota--Modelo: Daedong L2601 4WD. Serie:426600009.Tratare de averiguar el Kioti modelo LK3054 para ver si es el mismo.
/ Kioti L2601 #9
This thread is 5 years old...
/ Kioti L2601 #10
Good catch- once again suckered into a dead thread:duh:
CONEX BOX (A65643)
CONEX BOX (A65643)
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2018 DODGE RAM 2500 (A65643)
2018 DODGE RAM...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2012 Ram 1500 Crew Cab Pickup Truck (A64556)
2012 Ram 1500 Crew...
