KIOTI KL4030 vs KL4030C loader?
   / KIOTI KL4030 vs KL4030C loader?
Well that's cool they responded so quickly, where did you find their email address? I would like to clarify with them if the reach spec is measured from the front of the grill guard to dumped bucket edge on both loaders. Most other loaders I've looked at typically have a reach spec of around 20 inches.
It's nice that they confirmed that the specs are accurate; I was wondering if the extra rollback force on the C model was a typo because it is so much higher. I suppose this backs up my original opinion that the standard model may be better suited if you'll be loading a trailer or dump bed, but the C model may be better suited for digging or just picking up heavy bucket loads.
I've talked to a couple other dealers and so far everyone of them has basically said they didn't think I'd ever notice a a difference or be more limited with either one, which is probably true, but my recent experience unloading my box blade had me re-evaluating the limitations with a reduced reach.
   / KIOTI KL4030 vs KL4030C loader? #12
I found it on the Kioti website. In the contact us section, they have a customer service feature that I used. Give it a try, they will probably give you the specific answer to your question. For category, I clicked Technical Service and got a response really quick.
So I emailed Kioti and asked if the reach was measured from a different place on the two loader models, and they responded that they are both measured from the same place. So that would mean there really is a 16" difference in the reach. I did notice on the specs for the older KL2610 loader the reach is also 11.3" and looking at pictures of it the loader arms and mounting brackets look identical. I'm guessing they hired the manufacturer of the KL2610 to make the KL4030C with larger cylinders and possibly stronger loader arms.
   / KIOTI KL4030 vs KL4030C loader? #14
I think you might be right. It probably is a beefed up KL2610. I would guess that the "C" in 4030 then stands for Curved. Just a guess, but the top arms on mine are curved and shaped exactly like the KL2610.
   / KIOTI KL4030 vs KL4030C loader? #15
I have a ck3510 with a 4030c loader.. my QT failed a week prior to getting my recall letter and then it took three months to get parts and the new one lasted a half hour! The 4030c is in no way comparable to the 4030 in quality and durability.. plus kioti does not stand behind it. The 4030c is built very cheesy and literally tears it’s self apart. Kioti knows this is going on but they are doing nothing to take care of this issue
That is the first I have heard of the 4030C model having issues like that. Have you heard from other owners that have experienced similar issues?
   / KIOTI KL4030 vs KL4030C loader? #18
The 4030c is made by a different manufacturer than the 4030 and is in no way built to the standards of the 4030. Kioti is well aware of whats going on with these units. Mine is just one of many that’s why they recalled them ro try and stiffen up QT before more get torn off. So desperate to sell tractors they outsourced loaders..
   / KIOTI KL4030 vs KL4030C loader? #19
Can you provide a link or where we can find information on the recall you are talking about? I searched and do not see anything about a recall on the 4030c loader. What is in the recall letter? What specifically are they replacing?
   / KIOTI KL4030 vs KL4030C loader? #20
Interesting comparison! 9" of less loader reach is kind of a big deal - if you have to load a truck or trailer. Otherwise probably not much functional difference day-to-day. Unless your "Taesung" 4030C falls apart, that is.
My 2019 sindong 4030 is terrific, but is a little more flexible and loose than I might prefer (still have to install my hydraulic valve to cure the floppy bucket situation). Even with my backhoe on, the 4030 will pick up enough to lift the rear, if you try it. Over a face cord of wet oak in a crate, down a hill yesterday... puckered right up.
1998 Caterpillar 12H Articulated Motor Grader (A55973)
1998 Caterpillar...
2011 Ford F-150 Ext. Cab Pickup Truck (A55973)
2011 Ford F-150...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2022 RAM 2500 HEAVY DUTY (A58214)
2022 RAM 2500...
2025 BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2000 INTERNATIONAL 4700 (A58214)
2000 INTERNATIONAL...
